1 - 3 of 3 Posts
Greetings all, does anyone have suggestions for the VFCIII setting(s) for a 2009 Vision Premium with Lloyds Cams, Intake plate, VFCIII, Lloyds IAC Valve,Victory high flow air filter, S1L2 ECU flash, Atom Bomb exhaust?
VFCIII setting Template
1. Green Light only Feature:
2. Yellow Light Only Feature:
3. Red Light Only Feature:
4. Green / Blue Feature:
5. Yellow / Blue Feature:
6. Red / Blue Feature:
As a result of installing Loydz exhaust gaskets and Atom Bombs (recored stock exhaust) the power to the VFC was disconnected. kevinx01 did a FANTASTIC job of installing cams and configuring the VFCIII, but now I believe the VFC is operating in default mode. Some of the old symtoms have returned, but not as as intense. Symtoms are; backfiring or popping out exhaust after roll-out and coughing through intake.
Thanks in advance for your help.
Ride Safe
Tim
It is my understanding that the VFC module is solid state and, therefore, would not lose its settings when disconnected. It should be simple to check it and see if the current settings are those shown on Llyodz site as standard. Otherwise, even if it did lose its settings somehow, the tuning kevin gave it would be specific to your setup and someone else's would likely be different anyway.
1 - 3 of 3 Posts
