Long Range Shields | Victory Motorcycles: Motorcycle Forums
Long Range Shields
Discussion in 'Victory Cross Country' started by Smokier104, Jun 3, 2021.
  1. Smokier104
    Smokier104 Active Member
    Nov 4, 2018
    189
    129
    Eastern Iowa
    '14 Cross County Tour
    Greetings,
    Looking for some guidance, experience, recommendations regarding LRS (Long Range Shields) for the XCT.
    I am 5'9" (5'10' with shoes...). I prefer to look over most of the time and duck down when needed (rain).
    When I measure from the NOTCH at the bottom of the current shield, and get to a spot marked with tape I can see over, it is 13".
    That seems "tall" for a short guy. Am I miss measuring?
    If YOU have a LRS, which length do YOU have?
    How tall are YOU?
    Would you buy that same length again?
    Are you happy with your LRS?
    Thank you in advance.
    Ride safe,
    Smokier
  2. linerider
    linerider Well-Known Member
    Dec 22, 2013
    301
    332
    south central missouri
    '12 XCT and '02 TCD
    I had a a Long Ride Shield. Now using MadStad. much better.
  3. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    11,307
    4,772
    South Florida
    2011 Cross Country
    You want a flip shield to come to your nose height. 13” is too high. I have LRS on both my bikes. Like their tint the best. I’m 5-9” and I’m running the 8” Shields. I get no buffeting and clear view. You measure from the top of the opening / vent to the top of the shield. On a XCT you may want a 10” shield if you want a little more coverage.
  4. Blowndodge
    Blowndodge Well-Known Member
    Jan 31, 2013
    2,143
    710
    Utah
    2013 Victory XCT
    I have a 14" 7 Jurock smoked flipped windshield on my 13 XCT. I'm 6"1" 33 inseam. it comes to just below my nose. Seems about perfect.
  5. Smokier104
    Nov 4, 2018
    189
    129
    Eastern Iowa
    Ok, WHY do you feel the MADSTAD is much better? You need to sell it brother (convince me)!
    What didn't you like about the LRS?
  6. rustychevelle
    rustychevelle Active Member
    Jan 3, 2014
    272
    80
    Longview, TX
    Cross Country
    I am 6'1" with 34" inseem. I have a 13" LRS on my XTC and it is just a tad high. It will be way to high for you at your height. I would look at the 9" or 10".
  7. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,803
    1,201
    WV Appalachia
    Goldmist/Black 14 XCT
    5'9, have a 10" LRS. Madstad systems are supposed to get rid of all the buffeting effect, I personally don't like how they make the bike look.
  8. wvrider1
    May 20, 2012
    3,803
    1,201
    WV Appalachia
    They were just running MDW sale,
  9. T0ng5
    T0ng5 Member
    May 29, 2020
    57
    26
    Wichita, KS
    2012 Crossroads
    So I was looking at those Jurock windscreens a while ago for my XR (I have the stock one but it causes buffeting). First, why did you go with the flip and what is the benefit to it? Second, is the flip included in the measurement, or it is added?
  10. lou8700
    lou8700 Well-Known Member
    Dec 3, 2012
    5,483
    2,705
    St. Louis
    I have had the Jurock flip windscreen for several years. The flip diverts the airflow up higher over you. Include the flip in the total measurement from the headlight cutout of your oem screen. Good quality and a great small company to deal with.
  11. Blowndodge
    Jan 31, 2013
    2,143
    710
    Utah
    2013 Victory XCT
    The flip is added so that it throws the air up higher than a standard shield so you can get by with a lower height one. They are measured from the top of the bottom cut out to the top of the lip from the outside facing part of the shield. Without "lowers" or wind blockers on your forks it's almost impossible to get rid of buffeting. Most of that comes up from the bottom and is lifting your helmet. You have that so you should be good to go.
    I've had the 18" stock shield on and it comes up the the bridge of my nose. The 14" flip and the 18" stock one provides about the same protection from the wind. In the rain the 18" is much better.
  12. Smokier104
    Nov 4, 2018
    189
    129
    Eastern Iowa
    Greetings All,
    Thanks for the responses and ultimately the confirmation that a 13" was going to be too much.
    I am going to ride the current shield with some tape at the 10" line. Maybe sitting on the bike I am all messed up. :22yikes:
    Ride safe,
    Smokier
  13. linerider
    Dec 22, 2013
    301
    332
    '12 XCT and '02 TCD
    For me, the MadStad has way less turbulence than stock or LRS while at the same time being much shorter and easier to look over. It's also adjustable. Not as stylish as the LRS, but I sometimes take 2 week bike vacations so form follows function. My profile pic is with the LRS flip.
  14. Davisguard
    Davisguard Active Member
    Oct 3, 2018
    108
    55
    Stayton, Oregon
    2014 Vic XCT
    I put an LRS on my XCT. I'm 6 ft 2. I got the 12 and I look over it. No buffeting of wind issues. It helps my wife also when we ride together. I would go 10 or 8 but then my wife catches all of the wind.
  15. dave21042
    dave21042 Active Member
    Sep 22, 2015
    116
    32
    2012 Victory CC
    For those who have switched to the MadStad, did you put any weather stripping where the old windshield went between the fairing and the dash? I just went to the MadStad and want to seal up that gap created by removing the windshield.
