get a volt meter. There cheap auto stores sell them and so does walmart. Then you can check power.
I think you burned up your flasher with out it bike will not run right and signals will not work
OK I'll do that..a couple people said could be the flasher..just so I'm right your talking about the signal flasher relay?get a volt meter. There cheap auto stores sell them and so does walmart. Then you can check power.
Usually the right signal not working is a sign you burnt out your ACMsorry..should gave little more detail..I have leds on it currently. .the right side front signal doesn't work..my front brake signal works sometimes...all the rear signals work fine..on the right side the black is positive and the red and blue stripe is negative correct?
