Lloydz timing wheel torque setting | Victory Motorcycles: Motorcycle Forums
Discussion in 'Tech Q&A' started by boboxct, Apr 6, 2014.
  1. boboxct
    boboxct New Member
    Oct 30, 2013
    29
    2
    Pleasant Hill
    Cross Country Tour
    What do torque the two nuts that set timing?
  2. Lostintexas
    Lostintexas Well-Known Member
    May 13, 2012
    1,363
    143
    Almost East Texas
    Cross Country Tour (RIP)
    15 ft/lbs, 17 for the center. Use some lock tight.
  3. boboxct
    boboxct New Member
    Oct 30, 2013
    29
    2
    Pleasant Hill
    Cross Country Tour
    Thanks
  4. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    Torques are as follows....
    Bolt for wheel (13mm)(I added
    blue Loctite) = 15 ft. lbs. Oil the hole before installing and a screwdriver
    lodged between a tooth and a motor bolt holds it for torquing.
    Cover screws (5mm) = 6-8 ft. lbs. = 72-96 in. lbs
  5. boboxct
    boboxct New Member
    Oct 30, 2013
    29
    2
    Pleasant Hill
    Cross Country Tour
    Torque rookie here. I tightened my timing wheel bolts too tight with my socket wrench before I put the torque wrench on the bolts to torque them. Well, I kept applying the torque, and applying without a click on the wrench and stripped out the threads on the wheel. Just sayin, be careful....
  6. Oldman47
    Oldman47 Well-Known Member
    Mar 4, 2013
    6,181
    1,314
    Forsyth, IL
    2013 black Vision
    No torque wrench for me on the advance adjustment bolts, because I had no spec to guide me. So far my wheel is holding its adjustment after about 6 months and 6000 miles so I must have used enough and I caused no damage. Both of those bolts are between 10 and 15 ft lb and are about equal, I do have a bit of a feel for torque but my hands are not a torque wrench by any means. The center bolt I had a number so it got torqued to 17 ft-lb per the service manual spec.
    • Winner Winner x 1
  7. Kronker
    Kronker Active Member
    Dec 10, 2012
    236
    84
    Jackson, TN
    2013 Highball
    My instructionscame with "tighten two botls 12 to 15 ft-lbs"at the top of the page.
    I tightened to 14 and have had no problems.
    • Winner Winner x 1
  8. Big_Tav
    Big_Tav Member
    Jul 26, 2012
    311
    22
    Edinburgh, Scotland (Via Australia!)
    I am worried now. I haven't installed them yet but I didn't torque the outer ones. I just put a drop of blue on them and then I made them tight. Have I made a bad mistake? The centre one I will do to 17lb though.
  9. rman
    rman Active Member
    Mar 19, 2011
    122
    31
    meriden
    04 victory kingpin
    7-year-old post I know, but I have to weigh in on this one. Too many people are overthinking these torque settings on bolts there is most likely a torque setting for every bolt on the bike, but do you use a torque wrench to bolt your seat back down? Tight is tight All you need to do is use a little common sense when tightening down a large bolt or a small bolt. The two small ones on the timing gear you would not take a half inch drive ratchet and try to muscle it as tight as you can. If you do you probably shouldn't be doing your own mechanics work. Torque wrenches are meant for, i m o, tightening down heads connecting rods or where you have multiple bolts that need to be tightened at the same torque. ... By the way, what is the torque spec for the bolts on the license plate?
  10. primethious
    primethious Well-Known Member
    Aug 14, 2013
    8,045
    2,479
    2012 Victory Cross Roads
    The torque setting for those small bolts on the timing wheel changed as they were being stripped out. Lloydz send me a new wheel back then for that reason. Probably best to call them to confirm torque. On the second wheel I was told just snug with loctite.
  11. RidingAgain1025
    RidingAgain1025 Member
    Oct 24, 2020
    95
    70
    Palm Coast FL
    2013 victory cross country
    New torque on small side bolts are 6-8ft lbs I did 7.
how many for lbs for lloydz timing wheel
lloyds timing wheel torque
lloydz timing wheel
lloydz timing wheel install
lloydz timing wheel torque
lloydz timing wheel torque specs
lloydz timing wheel touque
loydz timing wheel torque settings
timing wheel lloyd
torque specs lloyds timing wheel
victory highball timing wheel torque ratio
victory motorcycle timing wheel crank bolt lbs
