Lloyds !/4 Turn Throttle Ring | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by Thumper, Jul 4, 2014.
  1. Thumper
    Thumper Member
    Jan 31, 2009
    425
    3
    Tacoma
    Just installed a Quarter Turn Throttle Ring on my Vision tonight. The Ring made a real difference in that it "woke the bike up." Throttle response is immediate. It you are interested, I suggest that you watch the Witchdoctors vid on installation.
    http://www.youtube.com/watch?v=WJwhR4XNKvw
  2. marvin24
    marvin24 Member
    Mar 6, 2011
    147
    4
    Mooresville, In.
    2013 Sunset Red Victory Vision
    I purchased the Quarter Turn Throttle Ring for my Vision, my question to you did you have to loosen the throttle cables at the throttle body to have the slack at the throttle to install, if you did how did you get a wrench on the nuts, very crowded in that area on my bike, I gave up on the install.
    Ride safe!
  3. crosscountryla
    crosscountryla Well-Known Member
    Dec 10, 2013
    8,363
    4,426
    2014 cross country tour
    I had the PCV timing wheel and air fitler from Lloyds , plus the Freedom Performance true dual exhaust. Recently I installed the 1/4 throttle and the Lloyds VM1-DR cams as well.In my opinion, the1/4 turn throttle ringand the Lloyds camsare agreat combination!
  4. Creek_IP
    Creek_IP Well-Known Member
    Jul 16, 2012
    1,410
    75
    In The Wiregrass
    Imperial Blue 2012 Cross Country
    I'm not on a Vision but on my XC I waited till I had the tank off for an air filter. When I looked at the tight space with the tank on, all I saw was frustration for me and my big paws.
  5. unbidden
    unbidden Active Member
    Jun 18, 2014
    685
    149
    RI / CT
    Victory Cross Country
    Installed the 1/4 T ring on my XC last week. Once you turn the throttle tension nuts a 1/4 to 1/2 turn you can loosen them by hand. I also suggest snipping the nylon ties that hold the cables to the frame, this allows for more play in the cables to slide the throttle sleeve off the bars. It's a simple reinstall of new ties to put the cables back in place.
  6. notaharley
    notaharley Well-Known Member
    Oct 1, 2012
    4,182
    1,822
    Effingham, NH
    VISION, BABY!
    How much did you pay for shipping on that? I went to buy one today, and they wanted $11 to ship it!! Not happening. I thought the charges were ridiculous. Did you do any better?
  7. shanko
    shanko Active Member
    Apr 8, 2014
    447
    90
    Cincy
    2011 vegas 8-ball
    Yea shipping is steep if that's all you get. I just bought more stuff so it bundled the shipping.
  8. ragtopdodge
    ragtopdodge Member
    Sep 11, 2013
    133
    6
    Seattle, WA
    2005 Hammer
    I had to grind and grind the inside of my starter/hazard switch housing for the two halves to close, but after all said and done, mighty impressed by the difference.
    Yes, I had to lift the tank and loosen the nuts. Not too bad, but still a PITA.
  9. unbidden
    Jun 18, 2014
    685
    149
    RI / CT
    Same deal here. That's the same B.S. that many vendors use to make the price look good but all in all, that ring is the best mod you can do for under $50.
  10. Ariesnc
    Ariesnc Well-Known Member
    Dec 19, 2013
    2,892
    837
    Fuquay Varina
    2015 Victory Magnum
    I have a 2013 hammer, was it hard getting the throttle housing back in place? I really would hate to have to grind the housing.
  11. crosscountryla
    Dec 10, 2013
    8,363
    4,426
    I agree!
  12. Ariesnc
    Dec 19, 2013
    2,892
    837
    Fuquay Varina
    2015 Victory Magnum
    Any suggestions on how to get the throttle cable nuts lose? Should I just remove the two bolts from the front of the gas tank to create some space in there? I have everything else set up but can't seem to get the throttle cable back in the slot on the throttle assembly to fit over the ring.
  13. shanko
    Apr 8, 2014
    447
    90
    Cincy
    2011 vegas 8-ball
    Not sure what you are getting at. Will it not fit into the housing? Sometimes you have to grind away part of the housing for it to fit. Also are you sure you have the correct ring for your grips?
  14. Thumper
    Thumper Member
    Jan 31, 2009
    425
    3
    Tacoma
    Loosening the throttle cables at the throttle body was a "pain" but the end result was worth it. It took a little longer than expected and my wife helped me (a litle) to reinstall the cables at the handle bar. Two hands were better than one! And YES you must loosen the cables at the throttle body to get enough cable "slack" to properly install the 1/4 turn ring as the ring took upALL of the cable slack. I then adjusted the cable at my handlebar to get it to rotate properly.It took about 1 hour+ for the complete install on a Vision.
  15. Creek_IP
    Jul 16, 2012
    1,410
    75
    In The Wiregrass
    Yes, grip has to come off the end of the handlebar like shown in the video.
lloyds throttle ring
lyodds throttel
victory throttle ring
vision throttle ring
