1 - 8 of 8 Posts
I just installed LED turn signals on the front and rear of my 2017 Gunner. I also installed a Custom Dynamics load equalizer that is made for this make, model, and year. I followed the instructions for installing the LE to a T. It's a very straightforward install and hard to get wrong. However, there are two problems I'm seeing after the installation.
  • The left turn signal flashes normally but when I engage the right turn signal, both sides hyper-flash
  • Both turn indicators on my gauge are constantly on when the turn signals are off
If anyone knows how this is even possible please help as I feel defeated with all the troubleshooting I've done. I can list the troubleshooting I've done so far if needed.
Thanks
You may need two load equalizers. One for each side. Vaguely recall that being brought up before somewhere here. Or I just made it up. :)
  • Haha
Reactions: Bikesofbrads
I busted out my trusty multimeter last night and figured out the problem. The instructions for the load equalizer show to splice the two hot wires to the blue and blue/red wires, and the ground to the black wire of the harness. BUT, the black on my harness is not a ground, said my multimeter. So I said, I'm gonna hook up the ground directly to the battery. And then life was all good :headbang:
Thanks
What does a qualified Auto Electrician say?
Not one but you have a short or a bad connection on the LE. The cluster light is a giveaway that there's current leakage into the cluster. Assuming you spliced the LE single wire to the ground circuit and the other 2 to the +12v lines on each signal. A couple diodes may solve the issue. Try un-splicing the right, see if it affects anything then swap and just the left.
My assumption is the LE has 2 5 or10w ceramic resistors in parallel with one side tied together with a single wire connection and 2 additional on the other side, 1 from each resistor.
I've not had any luck with the plug and play units so just made my own. 2 5w 10 or 20 ohm resistors and a couple 12v diodes should do the trick.
1 - 8 of 8 Posts
