1 - 4 of 4 Posts
Hi Guys, I have a Jackpot,09 and fitted the rear "MBW" leds to the fender. Looks awesome. The dealer told me to take the seat off and find the wiring harness, so i could fit the load equaliser so they would flash normally,which i did. The lights worked for a day then went back to flashing super fast again. Thinking a wire may have come loose, i took the seat off again, and rewired the module. Now my problem is, the flashing rate is good but my blinker light on the dash is flashing when i dont have the blinkers on. The blinker light on the dash is constantly flashing whether i have the blinker on or not :-(
Any help would really be apprieciated, Cheers Shrek
Have you contacted MBW with this concern??
Yeah sent an email to the supplier and received this back from the load equaliser manufacturer .
"> The power converter / load equalizer, doesn't have anything to do with the
> canceling of the
> turn signals. The load equalizer is a resister that makes the LED look
> like a 10W
> bulb. The older bikes didn't have self canceling TS. It could be the self
> canceling module
or it could be his TS module. i believe the dash LED gets the same
voltage that the TS get - so
I don't know how the dash would blink when the TS are not. Neither the
turn signals nor the load equalizer
> can cause the dash LED to blink. The TS module controls voltage out the TS
> are peripheral to it."
So i am wondering if i have shorted some wire or something.
yes..I would basically take things apart and work backwards to try to isolate the problem.
1 - 4 of 4 Posts
