1 - 2 of 2 Posts
I would like to add led dot lights to my lower bag fillers and my question is can I just tap into the tail light hot wire? Also is the DG/PK wire the hot for the tail light ? will I need a load equalizer to add these lights. Thanks, any suggestions would help.
Runnin' lights are: GN/PK
Left-turn: BU
Right-turn: BU/RD
Common: BLK
With Stingerz ya can put 'em where ever ya want (wire 'em directly into the present harness). They have adhesive on 3 sides. Clean the side ya don't use w/WD-40 (to get the tack off). If yer usin' the LEDs as a running light--no equalizer necessary. If yer adding the LEDs as turn-signals (i.e., not removin' the existin' lights)--no equalizer necessary. It's when ya replace incandescent lamps with LEDs ya'll need to add an equalizer.
These are VERY waterproof:
Amazon.com: Custom Dynamics Stingerz LED Accent Kit - Red STINGERZ99RED: Automotive
Volcome....
1 - 2 of 2 Posts
