Picked up a set of Kliphangers awhile back and finally got around to putting them on. Pretty straight forward pulled outer fairing, took out 4 bolts on inner fairing, left wires hooked up and was able to move it enough to get screws out of top bar clamp and swap bars.Put it back together and put on new Avon grips and 1/4 turn throttle ring. I adjusted throttle cables so it springs back when you release it fine. Moved grip and clamshell up to where pin fits in bar and throttle wont release, it just happens the last 1/2 inch sliding up the bar. Anyone have any ideas why?
