Kingpin Fuel Issues | Victory Motorcycles: Motorcycle Forums
Kingpin Fuel Issues
Discussion in 'Victory Kingpin' started by workingman, Aug 21, 2016.
Tags:
  1. workingman
    workingman New Member
    Aug 21, 2016
    4
    2004 Victory Kingpin
    I have a 04 Vic Kingpin that wont start. New Fuel pump and Battery. It pops when I'm trying to start it. When I cycle the fuel pump using the key or switch it charges for 4 seconds but doesnt seem to hold the pressure becasue when I do it again it cycles for another 4 seconds.
    When it was running correctly the pump would cycyle long then short and start up. I also reset the TPS.
    Any ideas?
  2. Kurbs
    Kurbs theVOG.net Gold Supporter Gold Supporter
    Dec 26, 2015
    6,933
    3,695
    2012 Victory Kingpin
    Sounds like a a bad pump. Should be 50 lbs. of pressure. Regulator is built into the pump. have to yank the tank off and pull it. Watch the cheaper aftermarket pumps. Spend a bit and get the OE one.
  3. workingman
    Aug 21, 2016
    4
    I thought the same when it first did it so I bought all new pump parts rebuilt it and put it back. So now i have two good pumps, one a year old and one new.
  4. Kurbs
    Dec 26, 2015
    6,933
    3,695
    Hmm. If thats the case...does it have a aftermarket controller on it for performance? If the pressure is there, thats all the pump does. I am thinking a bad MAP or controller or loose ECU wire?
  5. Hanuman
    Hanuman Active Member
    Feb 24, 2014
    320
    90
    Central PA
    '07 Ness Jackpot
    Did you pull a plug to see if it's wet? Do you have a fuel pump pressure gauge?
  6. workingman
    Aug 21, 2016
    4
    ok I will research that and see whats up.
  7. workingman
    Aug 21, 2016
    4
    fue pressure was good but no i did not pull a plug because of the symptoms it sounded like fuel.
  8. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    put in new plugs buy a couple sets.
    Then write Rylan at the vic shop about assembling your pump
  9. Kingpin50
    Kingpin50 Member
    Aug 15, 2016
    56
    14
    Central Ga
    07 victory kingpin
    It sounds dumb,but I would check to make sure you didn't crimp the fuel line under the tank.(if you pulled the gas tank)
  10. kaitiff
    kaitiff Well-Known Member
    Dec 18, 2012
    6,843
    2,668
    Mathews, VA
    14 XC/07 KPT
    yah, instead of guessing if you have fuel pressure.. check it. You can rent a gauge if you don't have one.. but it's not hard to check.
    There is a video on here from the vic motor shop that has a really nice 'what to check on a bike that won't start'. It's not comprehensive but it does a damn good job on the process and what to check.
  11. tree1979
    tree1979 Well-Known Member
    Jan 10, 2014
    4,221
    1,391
    Birmingham, AL
    2007 Victory Kingpin
    Watch this. Good info. Just because it cycles each time you flip the switch doesn't mean anything. You should do this several times anyway if you run out of gas to re-prime the lines. Check your voltage. Could be a bad battery causing it to not fire. Agree with replacing the spark plugs. I do it every spring. If you think its fuel related, take the main hose loose from the nipple under the tank. Attach a clear hose (get one from lowes or somewhere similar) and put the other end in a gas can. Flip the switch. If the pump is working you'll get gas flowing.
fuel pressure regulator location 2004 victory kingpin youtube
2004 victory king pin fuel pump relay location
checking fuel pressure on a 2007 victory kingpin
victory kingpin fuel regulator
victory kingpin low fuel pressure
what company originally built the fuel pum for a 2007 victory kingpin tour
where is the fuel preesure regulator located on a 2007 victory kingpin
