I need some advice on this install. I posted this on the VMC site as well.
Neal recommends removing the mufflers in order to loosen the crossover pipe behind the engine. The crossover has to be loose to install 2 of the 3 bolts that hold the stand to the back of the engine - otherwise, the crossover is in the way and you can't install the bolts.
The problem is - I have a Busthtec hitch. The side supports for the hitch line up right behind the bolts holding the muffler to the bike, and so the mufflers are not coming off unless I do a full rear-end strip and re-build. I had to do that to install the hitch last year, and I'm not ready to go through that exercise again just yet...not difficult, it just takes (lots of) time.
Has anyone else out there found a way to install Neal's stand without removing the mufflers? I would guess that anyone out there buying a Vic centre stand would run into the same problem.
Thanks!
Thanks!
