1 - 9 of 9 Posts
Pull back the clutch lever on the extended rod that is attached to the shifter shaft just like you do with a clutch on a handlebar and then use the foot shifter like you do on a regular bike.
Shift like you normally would but with your hand. I understood what you meant.
The key looks like it's in the way. It obviously must not be but it looks close.
If you notice the offset on the extended shifter rod, you'll see that the offset if made this way to clear the key.
I'm sure it does. I just think I wouldn't like trying to stick that little key in with my big man hand.
I like the look and my gripe is a tiny one.
1 - 9 of 9 Posts
