1 - 1 of 1 Posts
Supporting Vendor
We are very excited to release our new "Stocker" 18x8.5 rear wheel for the Indian Scout. This wheel is designed to match the factory front wheel and allows you to easily install a massive 240mm rear tire on your Scout when used with our Scout 240 Wide Tire Kit. What makes this "Stocker" wheel great is that it uses the factory rear rotor and pulley which saves you the cost of having to purchase a front wheel and matching components.
Our Scout 240 Wide Tire Kit, supplies you with everything you need to easily install a 18x8.5 rear wheel on your Scout with no modifications.
Here is a list of what is included:
  • 18x8.5 "Stocker" rear wheel
  • 240mm Metzeler tire
  • Reinforced steel fender (setup to use factory tail light and signals)
  • Chrome license plate mount
  • Belt guard
  • All necessary spacers and hardware.
MSRP: $2495.00
1 - 1 of 1 Posts
