Found this post on Face Book on the Indian forum there.
THINKING OF FUEL TUNER? Just an FYI.
Sharing my experience.
I just picked my bike up from the local dealer.
It was there for the motor "clacking" that a lot have been reporting. Mine has slowly become louder after a 2500 mile trip.
Mine motor started the noises shortly after my Indian Stage 2 Cams were installed at 1728 miles on 7/21/17. I didn't think much of it. Figured it must be the valves with the high lift.
At the beginning of this riding season in the North East (April for me) I noticed it seemed to be a bit louder. I mentioned to the dealer and they said it's all normal.
During my West coast trip this summer the noise just kept getting louder. Especially when two up and loaded. I dropped it off to have it diagnosed.
My dealers first response last Tuesday was that it's just normal piston slap that all the 14-17 motors have due to the design. I insisted that this was more than piston slap. I expressed my displeasure in purchasing a 33k Icon series RM to have this piston slap that might not be mechanical problem now but IMO will be in the next 75,000 miles. It sounds horrible. He asked if I had a Fuel tuner. I was honest and informed him I had installed a Dyno Jet tuner shortly after the Cams were installed. His tune immediately changed. He said he would be back in touch.
Wednesday the dealer called to inform me tuners do not work on the Indian ECU. As the Indian tuner is fighting with the Dyno Jet Fuel map. My pistons are now considered damaged due to lean conditions and not warranted by Polaris/Indian.
Dealer insisted that I put the Indian Stage 2 download back on the bike. But not until I paid 220.00 for another download code. (Currently Disputing this with Polaris/Indian)
Today I picked my bike up. I asked the dealer what type of diagnosis was done to determine that my pistons were damaged by a lean condition. Visual scope, compression test, valve seal pressure test? Opened the motor?
Greg White
August 31 at 9:59 AM
Just spoke with Indian Customer Service.
Indian has agreed to refund the 2nd purchase of the stage 2 download.
Unfortunately, it seems I am SOL with my engine noise. The dealer is standing by the fact that my fuel tuner caused what ever is making the noise In the motor. Even with zero diagnostic work they are confident that the motor is damaged and the cause is the fuel tuner.
****Update. I called back to confirm that Indian wasn't going to look into my motor noises any further. I was told. They would not do any more than they already have. They already authorized the 220.00 refund for the stage 2 tune and that the tuner comprised the motor. Any damages to the motor should be taken up with Dyno Jet.
Learn from my mistake. Don't add a fuel tuner until your warranty is expired.
I've been messaged by other owners that they've had the noise for many miles and zero issues.
I've done my own diagnostic work. Compression is good. Oil change had no abnormal metal in the pan. Oil filter as well. Oil didn't smell like fuel. I will be using a bore scope this evening to look inside the cylinder.
Anybody want to buy a 2017 Icon RM 7200 miles. 24,500
NOTHING other than a test ride to listen was done.
So basically Polaris is going to rest their lousy piston design on you if you have any aftermarket tuner.
Dealer did give conveniently give me an estimate for having the 2018 pistons installed. Next spring I will most likely have the big bore kit installed. If I don't sell it prior.
Photos from dealer included.
This post is by no means a slam on my dealer. Their hands are tied. They will only do what is authorized by Polaris. As well as relay info from Polaris. It's clear Polaris has washed their hands of my piston slap issue. Without ever even looking into the motor.
As they will do your if you put any other tune besides Indian.
My bike still runs fine. Not as well as it did with the Dyno Jet tune...but it still runs. It just has that Dam clacking noise from 2100 to 3000 rpm.
Greg White
Below is a another very good article about the why the big inch Indian's clack
My Indian Roadmaster
Greg White
Greg White
