1 - 3 of 3 Posts
Automotive tire Rim Bicycle part Motor vehicle Gas
Wood Art Metal Glass Copper
So this is the new Polaris Indian updated Segar, slightly bigger, louder, and handles water better horn. On all the big baggers and FTR. I had some blade connectors and the small ones will work here. You can make a harness or just JB weld on the old blades on the side of the connector. Fill the plug with RTV sealant and this horn should last for years. I did grind down the Grill some around the horn. Its going to fit with a slight clearance of the grill. Clears the oil cooler no problem.
How does it sound like? Maybe... Hi how are you, Hi how are you
1 - 3 of 3 Posts
