1 - 4 of 4 Posts
What I need is the 4 pin connector on the harness side of the ignition switch connection. I'm using pigtail connectors now. Because the harness side pins became defective. I purchased a new gas cap which came with a new ignition switch. So I want to replace the pigtails with the proper connection. Any help would be gratefully appreciated. Thanks in advance.
Respectfully
Richard
If you go this route, be sure to slip on heat-shrink tubing before soldering each connection. Then after making each connection, be sure to shrink the tubing around it so you prevent corrosion from starting.
Thanks for responding so fast. This is exactly what the doctor order. And the shrink tubing idea, I can finally rationalize buying that big box of tubing.
Respectfully
Richard
1 - 4 of 4 Posts
