Just picked up a 2011 Kingpin with 5000 mi. and was looking for the idle adjustment screw with no luck. It apparently is not in the same area as my 2004. The only thing I see from the right side of the bike looks like a small stud with a lock nut on it. My bike is idling a little low, it is fine when cold @1000 rpm but at about 800 when at operating temp. Also does the 2011 require the throttle bodies need to be cleaned like the older bikes? If that is so I would probably do that first. Hope someone has an answer.
