I drowned my Vision | Victory Motorcycles: Motorcycle Forums
I drowned my Vision
Discussion in 'Victory Vision' started by Teflonpilot, Nov 16, 2021.
  1. Teflonpilot
    Teflonpilot Member
    Aug 16, 2020
    56
    44
    South florida
    2009 Victory Vision street
    Battery, solenoid, or something else?
    Heres the background...I rode my 2009 Vision to Sturgis -from Ft Lauderdale, 4600+ miles in 10 days. I must say, Jolene will never have to prove herself to me or any of the boys again. She rode like a champ! Best motorcycle ever!
    I deployed 2 days after getting home. So she got rode hard and put away dirty.
    fast forward 4 months and I'm home. Connected the battery- she fires right up. I do a quick shakedown ride, check tires etc.. then I pull into a car wash to blast some of the hard caked bugs off of the bike.
    I was over zealous with the pressure water, I admit, so now the bike wont crank. The battery charges on the tender, the bike lights up, but the moment I try to crank the bike just goes black. Completely dead.
    Did I fry the battery somehow?
    Fuses seem to be ok
    Is it the solenoid?
    Its been 2 days now so the bike is dry. No change, she charges, lights up but dies the minute I hit the crank button
    BTW Im have only the most basic understanding of spark and I DO NOT even own a voltmeter
    Im about to jump the bike to a car battery.
    Any thoughts or advice? Thank you guys in advance!
  2. ByteN2it
    ByteN2it Well-Known Member
    Mar 15, 2010
    1,414
    1,013
    '99 V92C & '09 Vision
    Eventually it should dry out & get back to normal. You can speed up the process by going through & opening up all the electrical connection you can get to, blow them out with compressed air & seal up with silicone grease for future protection. Some WD-40 inside the sparkplug caps on both ends & hitting the entire bike with a leaf blower to help dry it out. Be careful jumping the battery-don't have the vehicle running, just use the battery on it's own.
    • Agree Agree x 5
  3. Teflonpilot
    Teflonpilot Member
    Aug 16, 2020
    56
    44
    South florida
    Thanks for the advice. But still, why does the battery dump its charge as soon as I hit the go button?
  4. md2420
    md2420 Well-Known Member
    May 10, 2016
    2,758
    1,229
    Chandler, AZ
    2014 Vision
    guessing that when you hit the start button it “should” divert all power to the solenoid/starter for that moment.
    sounds like a bad connection somewhere. Likely needs to dry out more.
  5. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,722
    2,416
    Littlestown
    1st confirm that the cables are clean & tight (every cable has 2 ends).
    Do you have +12 Volts on the gauge before you hit the button?
    How long before it comes back to life? The 40amp breaker could be the culprit.
    Cleaning tip, use you favorite detailing spray and a couple dryer sheets to remove those dead bugs.
    • Agree Agree x 4
    • Winner Winner x 1
  6. Bikesofbrads
    May 16, 2020
    2,980
    1,877
    South central/eastern ohio
    2015 victory xct & 06 katana
    After that many mile round trip ride to sturgis my bets on battery cables vibrated loose, check with a wrench because your hand will lie & next time go a lil easier with the power wash
    • Winner Winner x 1
  7. don07tncav
    don07tncav Active Member
    Sep 23, 2012
    300
    172
    Middle Tennessee
    Two 2009 Victory Visions and 1975 RE5 Suzuki
    As mentioned, check that breaker. tighten the cables, and be sure everything is dry. Did you blow the water out of the spark plug holes too?
  8. Chattanooga_Mark
    Dec 25, 2009
    5,663
    2,583
    Chattanooga
    2012 CCT, Wonderful in white
    Note to self: never, ever use a pressure washer on your Victory.
    • Agree Agree x 5
    • Winner Winner x 1
  9. Motorbikerx
    Motorbikerx Well-Known Member
    Dec 27, 2013
    1,354
    1,271
    Gold Coast, Australia
    2010 XC 2006 KINGPIN
    Yo
  10. Teflonpilot
    Teflonpilot Member
    Aug 16, 2020
    56
    44
    South florida
    Once the battery comes to charge on the tender, when I open the ignition I get 14 volts- which is normal. When I hit the start button the bike goes completely dead.
    Where is the 40 AMP breaker located?
  11. Teflonpilot
    Teflonpilot Member
    Aug 16, 2020
    56
    44
    South florida
    I know, man. I know.
    • Funny Funny x 2
  12. Teflonpilot
    Teflonpilot Member
    Aug 16, 2020
    56
    44
    South florida
    Ill check the plug holes. But the boots are super tight
  13. md2420
    May 10, 2016
    2,758
    1,229
    Chandler, AZ
    2014 Vision
    left side of the bike under the plastic flappy cover up by the battery
  14. Flyboy
    Flyboy Well-Known Member
    Aug 29, 2014
    16,614
    6,396
    Victory Boardwalk
    Yeah I heard those 40 amp boogers like water...
  15. jmstang302
    Aug 18, 2013
    5,722
    2,416
    Littlestown
    Sounds like a bad/lose connection, happens within a second of touching the starter button.
    If the battery bolts are just a thread or two too long they will bottom out without clamping the terminal tightly.
