I didn't know Victory had this made... | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by KeepRidin!, Nov 28, 2020.
  1. KeepRidin!
    KeepRidin! Well-Known Member
    Dec 2, 2017
    1,070
    537
    2008 Victory Vegas Jackpot
    I saw this at a motorcycle dealer today. I always thought that there was just the 20W-40 Victory oil, didn't know they had this too. 15W-60, seems like it would be really thick. Does anyone in here use this stuff?
  2. Known1
    Known1 Well-Known Member
    Apr 30, 2012
    4,421
    1,436
    Cement Slab, MN
    2013 Cross Country Tour
    That oil was produced for the Victory Octane. With that said, the newer owners manuals for the cross and vision bikes stated you could run this oil as well. I personally haven't heard of anyone doing so.
  3. Motorbikerx
    Motorbikerx Well-Known Member
    Dec 27, 2013
    399
    404
    Gold Coast, Australia
    2010 XC
    wouldnt do any harm...except to the hip pocket...Vic oil is overpriced for what it is....
    • Agree Agree x 5
  4. Bikesofbrads
    May 16, 2020
    984
    591
    South eastern ohio
    2015 victory cct & 06 katana
    I’ve heard alotta talk about Spectro being a good alternative, @slickvic is starting 2 haunt my oily dreams haha
    • Funny Funny x 5
  5. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    10,625
    4,374
    South Florida
    2011 Cross Country
    Your starting to worry me. That’s not a good pic in my mind lol.
    • Funny Funny x 4
  6. Bikesofbrads
    May 16, 2020
    984
    591
    South eastern ohio
    Hey that’s ur own fault, I never said to “picture this” lol
    • Funny Funny x 3
  7. PreachSF
    PreachSF Well-Known Member
    Dec 3, 2012
    1,600
    1,030
    Delray Beach, FL
    that was for the Octane ONLY ..... DO NOT USE IT IN THE 92/100/106 Engines!!!
    • Agree Agree x 6
  8. Blowndodge
    Blowndodge Well-Known Member
    Jan 31, 2013
    1,993
    622
    Utah
    2013 Victory XCT
    Another oil warning! Love it!
    • Funny Funny x 1
  9. Bill21
    Bill21 New Member
    Nov 10, 2020
    4
    1
    Indian Scout
    Indian Scout came from the Victory Octane. Revs to 8300rpms so it needs this heaver oil.
  10. John G
    John G Active Member
    Jan 27, 2015
    266
    75
    Northwest
    Victory Vegas 8 ball
    I really wouldn’t go with a higher viscosity oil. The reasons: You don’t know what the clearances set inside the engine were designed for as far as oil viscosity. They may be just fine with a heavier oil, but maybe not? I wouldn’t screw with it, particularly because I don’t see the benefit of it.
    Back in the day when I worked on round aircraft engines, Pratt and Whitney R1830, 1340 etc, they used W120 which was a 60 weight oil. Single grade. The oil was so thick that when you shut down in winter, you had to use the oil dilution system to introduce gasoline into the oil system to thin it out before shut down. Otherwise you wouldn’t get it started.
    The reason for the thick oil was the massive clearances inside the engine, and the wide operating range, from the South Pole to the African continent. However, when Phillips introduced the first multi weight aircraft oil, which was 20w60, they used a Pratt and Whitney to do all the testing. The end result was that the multi weight oil provided less wear than the straight 60 weight. No surprise.
    When you think about it though, what is the benefit of a higher viscosity oil in a Vic when it’s hot? None that I can see. You want the oil to circulate fast and cool through the cooler to keep internal operating temps down to where they were designed to be.
    The biggest advantage I can see for an air cooled engine, whether it be aircraft of motorcycle, ATV or whatever is to use either a synthetic or semi synthetic oil. I don’t feel that the brand is important, although everyone has their faves, and that’s cool. Some exotic oils have additives that may or may not help engines. But to me, it’’s all about consistency.
    The biggest help on any aircooled engine is to let it warm up proparely before taking off, and staying off the throttle until she is fully up to temp. Then you can do what you like with it without fear of wrecking it.
    The Victory short skirt pistons are great for reducing mass and inertia, but they are prone to rocking side ways in the bore when the engine is cold. Hence the requirement in the manual to let it warm up at idle for a minute minimum before taking off cold. Vics aren’t the only engines with short skirts,and there are lots of others that have a them.
    It’s worse in an aircooled engine as the internal clearances, piston to bore, ring gap, connecting rod pins, bearings etc have to be a little larger because the engine runs hotter than a liquid cooled motor.
    So, in my humble opinon, don’t screw around with a heavier weight oil. Just saying.
    Cheers
    • Informative Informative x 2
  11. primethious
    primethious Well-Known Member
    Aug 14, 2013
    7,955
    2,419
    2012 Victory Cross Roads
    I've run 20w50 in mine for over 30k miles with no issues.
    Slightly thicker oil keeps the gear wear to a minimum.
    • Useful Useful x 2
  12. John G
    Jan 27, 2015
    266
    75
    Northwest
    If it works for you, that’s good. I’ll just keep to the recommended weight. Remember though, that increased viscosity won’t necessarily protect the gears. It’s the additives that help the oil cling to the gears that reduce wear. Personally, going up 10 to a 50 wouldn’t be a big deal. Going to a 60 wt might not ever make a difference either, unless you are racing and putting on extreme stresses. Back in the 70’s they used to claim that multi weight oils never came up to their rated viscosity at temp, but I think that was tribal knowledge too.
  13. jedi-mcfly
    jedi-mcfly Well-Known Member
    Sep 11, 2014
    9,429
    3,115
    Alberta
    2005 kingpin
    • Winner Winner x 1
  14. slickvic
    Dec 22, 2011
    10,625
    4,374
    South Florida
    2011 Cross Country
    Oil has come a long way. From aftermarket oil additive products for added protection to spray lubes and greases. Now car finishes like ceramic and polymer coatings. Some good some hype. Find what works for the masses sharing the same platform and I generally tend to go in that direction.
  15. Ghostrider25
    Jun 22, 2014
    6,561
    3,003
    S.F Bay Area
    Respect! That must have been very interesting work. Had I not landed in the technology field I had a sense that I would enjoy this career as well.
