You may remember the hydraulic jack that I use in my motorcycle videos.
My wife picked it up from Canadian Tire in 2012 to use on my Triumph and I have also been using it on my larger Victory.
One of the things that it always did was bounce while lowering. The motorcycle would shake and I would have to delicately use the foot pedal to lower it very slowly so it would not do this.
Well the other week I was going to use the jack and to my surprise it would no longer lift the bike up.
I checked the usual things but it just wasn't working.
I took the bottle jack off the frame and decided to change the oil and bleed it.
You can see in the picture the difference from the old oil on the left compared to the new oil on the right.
I reinstalled the jack onto the frame and it was now able to lift the bike easily. I also noticed that it was a lot smoother to lower. No more shaking. It was beautiful. This is the way it should have always been.
I don't know if it was caused by air bubbles or cheap oil from the manufacturer, but maybe if your jack does this it could be a simple matter of changing the oil.
I just wanted to pass on my findings and perhaps it will help someone and hopefully save you some money.
