How to feed CB sound into XC sound system? | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by SMM28, Apr 13, 2013.
  1. SMM28
    SMM28 Member
    Dec 23, 2012
    303
    21
    2011 Ness XC #173 & 2007 Ness Jackpot
    I installed a Cobra CB and it has a speaker out on it. Is there a way to feed this sound into the stereo similar to the way that the Vic GPS feeds in where the GPS sound temporarily takes over the stereo?
    Can I use the Vic Audio Harness Package Item #: 2878065?
  2. EIGHTYEIGHT
    EIGHTYEIGHT Member
    Jul 20, 2012
    250
    4
    Plano
    2012 Cory Ness Cross Country #88
    Nope.. The only things that can plug into that harness are the proprietary victory devices (xm/cb/bluetooth)
    Does the cb have a 3.5mm out? If so you should be able to use the 3.5mm aux in cable (bout 40.00). You would have to switch input modes to the aux/mp3 input using the mode button so it won't really do what you want (override music) as you are on a different input and would only be a able to hear the aux input device.
  3. MightyMutt
    MightyMutt New Member
    Oct 19, 2012
    10
    Manchester
    2013 Cross Country Tour
    What Cobra did you install? Just wondering I want to put a CB on mine without paying $400+
  4. SMM28
    SMM28 Member
    Dec 23, 2012
    303
    21
    Cobra 75WXST
  5. SMM28
    SMM28 Member
    Dec 23, 2012
    303
    21
    Yes, It looks like a 3.5mm out. Do you happen to know the part number of that 3.5mm aux in cable? Where does it plug in? Also, Im already using the iPod cable...does that tie up this Aux input?
  6. mjw930
    mjw930 Well-Known Member
    Oct 23, 2009
    3,395
    426
    Ormond Beach
    Octane
    Yes, the iPod cable uses the Aux input plus an added control hence the 2 cables connecting to the iPod adaptor. The aux input adaptor uses one of the jacks used by the iPod adapter, you can't have both connected at the same time. I tapped into the audio portion of the harness on my XC so I could use either but obviously only one at a time. Note, using this as a CB in means you lose all other radio functions while using the CB AND you only get the receive portion of the CB, you can't transmit via your headset. Reality is if you want on board CB buy the Victory factory unit, it's fully integrated and it works. Everything else is hack at best and by the time you buy all the adapters and rewire everything you don't save that much money.
  7. Bob_b
    Bob_b Member
    Jun 19, 2014
    33
    6
    Navarre, FL
    '04 V-Star 1100; '14 XCT
    Can anyone still buy the factory unit for a XC? I had one installed on my XCT when I bought it last year. We had to search the globe to find the wiring harness for it. Victory removed all references to the CB in their info halfway through 2014 for cross country models. They still listed it for the Vision, but it used different parts (or so I understood).
    I'm currently troubleshooting my CB. The range on it is terrible. Since I have a XCT, the antenna tilts back. I can rarely talk with riders more than 50' away. Also, the Victory headsets (made by N-Touch) are garbage. After going through three rider sets, I bought an EdSet.
  8. jenkins
    jenkins Active Member
    Jan 20, 2013
    396
    85
    Coupeville, WA
    2012 Victory CCT
    Check your connection at the antenna, very carefully. Seems some have had to add a plastic spacer to keep the antenna from grounding out at the connection point.
