The plastic pins in the hinges are split down the middles and snap together. You have to separate the two halves to remove the pins. Once the pins are out, the clear deflectors will come off the black plastic. Make sure the two halves of the pins completely snap together when reinstalling. If not, they WILL fall out while riding. Yep... had it happen!Anyone ever done it? I just bought some, and one is clear and the other is badly yellowed; if I can take them apart I'm hoping that I can have vinyl put on them to clean them up.
Any ideas are welcome.
Thx,
Kevin L
How did you get them apart? Does the small part of the pin come out first? I've tried pulling/pushing/prying/lifting and I can't get it to move!once you get them apart, do yourself a favor and replace the pins with bolts, a pair of washers and a self locking nut. Did that on mine. Part of the pin fell out on one and I almost lost the deflector. Just don't over tighten the bolts. Works better than the pins did.
I can probably do better than posting a link. I think I have a spare pin that I ordered to keep on hand. If you can wait until this evening, I'll post a picture of the two pieces and how they lock together.Thanks Poseidon; I can see where the "pin" appears to go in on the bottom bracket, just can't get them apart.
Do you have a good link for the parts diagram? I'm not having much luck finding one.
Thx,
Kevin
Item #10 in the link below (multiple items labeled #10 so look at the part numbers)Thanks Poseidon; I tried their website and can't get that p/n to pull up. I'll try a different pc later on.
BTW - I still cannot get those apart! Thinking I'll have ti drill them so I can clean & paint the deflectors, then replace the pins.
Thx,
Kevin
I'll let you know how they work out, if the freaking weather ever cooperates! 21 degrees in VA yesterday!I'm still dithering over what kind of deflectors to get for my 14 XC. I need something.. the previous owner put a CFAD on but the wind coming under the fairing on the sides is a *****. I hadn't thought about how the fairing deflectors might be problematic versus the fork mounted ones. Hm.
