How cold can it be to start my Vic? | Page 3 | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by Tenax66, Dec 25, 2018.
  1. nickr914
    nickr914 Well-Known Member
    Sep 22, 2012
    2,361
    709
    Ya, firing it up, running for a little bit then shutting off is a moisture trap.... Either way, I change my oil right after winter.... I believe in fresh oil beginning of the season...
    • Winner Winner x 1
  2. greasemonkey
    greasemonkey Active Member
    Jan 1, 2013
    499
    90
    Sedalia, Mo
    Victory Crossroads
    Does your car use 20w oil? No new cars do...my Victory wouldn't start if it was much below 40 for any extended period of time.
  3. poptop
    poptop Well-Known Member
    Apr 25, 2010
    2,643
    634
    Vermilion
    09 Black Kingpin Prem rpw Thor 2 into 1. cams and ajustable timing wheel S+S intake and flash
    Ive seen people use propane bull tourches in an old stove pipe you can bet your boots that gets the temp up quickly hell when I was growing up on a farm many years ago we built smal fires under the tractor and built a shroud around the tractor to keep the heat in ,useualy took an hr or so to bring it up to temp so you could crank start it!
    Worked fine ,
    Could t do that with an old HD ,to many oil leaks!
    Sorry about that poke folks could not resist!lol
    • Funny Funny x 1
  4. topcat
    topcat Well-Known Member
    Aug 10, 2013
    823
    259
    Peoples Republic of New York State
    2011 Kingpin
    I'm sure there is a 20 in there somewhere I use 10W30 full synthetic in my truck.
    I use 5W40 Rotella full synthetic in the bike.
    Seriously, your bike wouldn't start if it was much below 40 for any extended period of time.
    Maybe your battery was old and losing power in the colder temps.
    • Winner Winner x 2
  5. poptop
    Apr 25, 2010
    2,643
    634
    Vermilion
    If I had to wait till it got to above 40 degrees above f I wouldnt b3 able to ride till june and shut down by the first of september!
    You definetly have other issues if the bike is hard starting even at freezing point and colder!
    Better get you bike tuned and have them do a diagnostic on electrical if thats the case!
  6. Old Sarge 3/12 Cav
    Old Sarge 3/12 Cav New Member
    Apr 7, 2017
    2
    1
    Victory Vegas and cross country tour
    Yesterday I pulled out my 07 Vegas and she cranked right up, it was 12deg. I'd say it was a bit cold and let her run, thies Victory's are built tough, I got a 2013 XCT and the coldest I rode her was 32deg. across the desert at 70mph. now that was a cool ride. As for cold weather storage I keep a battery charger on both bikes and I try to start up both bikes every couple of weeks and let them run till up to temp.
    • Agree Agree x 3
  7. Cobra Rider
    Cobra Rider Active Member
    Oct 22, 2016
    865
    210
    Moreno Valley, CA
    2014 XCT, 2011 XC, 1999 Suzuki LC
    WTH? Selling it?
  8. Trout
    Trout Well-Known Member
    Nov 21, 2015
    2,346
    1,240
    G'ville FL
    2013 XCT, 1989 Guzzi Mille GT, 2001 Guzzi Jackal, 2013 Guzzi Griso
    My XCT lives outside all year. This time of the year mid 20's for a few days is normal. 63,000 miles of this & no problems.
    HOLD THE STARTER BUTTON DOWN UNTIL IT STARTS!!!! If the engine kicks back & breaks the starter sprag kiss about $300.00 g'by.
    Let it run until cylinders are warm to touch then ride for at least 25 miles to burn condensation.
    • Winner Winner x 1
  9. Tenax66
    Tenax66 Active Member
    Aug 12, 2017
    960
    202
    Victory magnum 2016
    Passively. If I get the right price. If not I'll try to find a way to keep it
  10. Sutherland
    Sutherland Well-Known Member
    Aug 23, 2009
    2,922
    207
    Sampsonville
    08 Kingpin/2013 CCT
    I have started both of my two bikes (08 KP 13 CCT) in cold weather down to minus 20 C with no problem. I make sure I twist the throttle a bit and crank them over till they start, never take your thumb of starter button until it starts ( as mentioned above started clutch problem) I run them until they warm up at around 1200/1300 rpm's then let idle till I can not put my hand on top of heads, shut it down and thats that. Have never had the need to replace perfectly good motor oil with the same perfectly good motor oil.
    Regards
  11. iabob
    iabob Well-Known Member
    Dec 20, 2010
    17,070
    5,449
    Des Moines
    Victory Kingpin
    This bike was a shaker rig tester for Polaris, never registered but put hundreds of thousands of miles of wear and tear on it in testing before it went to Sweden to be frozen in a block of ice for FOUR years as a decoration. Any guesses as to what happened when they thawed it out?
    • Informative Informative x 2
  12. Trout
    Nov 21, 2015
    2,346
    1,240
    G'ville FL
    Yeah that's cool.
    BUT starting it and then putting miles on it are two very different things....
    Just sayin.
  13. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    12,058
    5,214
    South Florida
    2011 Cross Country
    What was the point of trying to destroy a bike then resurrecting it ? Oh yeah. I used to keep my CB350 outside during the cold Conn winters. Covered with plastic and snow. Lol
  14. iabob
    Dec 20, 2010
    17,070
    5,449
    Des Moines
    Victory Kingpin
    The bike never got a VIN number, it was never going to be sold to a rider. After being abused by Polaris on a shaker rig to see what 300k miles do to a Victory they sent it to Europe to be repeatedly torn down and rebuilt training techs over there. After they were done with that abuse they let a Swedish ice hotel use it as a frozen in ice decoration for four years. Point was a Victory can take all that abuse and still start and run so I think the OP will be fine if the temperature is 20 degrees.
  15. nickr914
    Sep 22, 2012
    2,361
    709
    Why you picking on me!!!!
    • Funny Funny x 2
how often is there frost in victoria motorcycle
