How can you tell if you need a new shock/spring? | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Vision' started by Bam'sVision, Jun 3, 2020.
  1. Bam'sVision
    Bam'sVision New Member
    Mar 1, 2015
    24
    1
    Kansas City, MO.
    08 Victory Vision (Retired 1998 Honda CBR 1100XX, 1994 Kawasaki ZX6)
    It's a squeaking noise from under my seat I have lubed everything i can find under there. I'm now starting to think it's the shock or something but my vision still rides as smooth as when i bought it. It doesn't ride hard or stiff but this dam squeak. I'm not sure how shock/springs are when they go bad but that's what I'm thinking. Any ideas would be appreciated.
  2. turkishexpress
    turkishexpress Member
    May 29, 2016
    72
    16
    Chicago, IL
    2013 Victory Vision Tour, 2015 KTM SuperDuke 1290 R
    Usually if the shock "goes bad", the piston seal gives out or leaks and the spring has to do majority of the work. The bike will either bounce in the rear if you're light or bounce and bottom out constantly if you're really heavy. Check your swing arm pivoting points and where the shock is attached to the frame. See if any of the bushings has worn out or needs to be lubed.
    Also since I'm a bit anal about my suspension, I like to refresh it every few years if it's a street bike. 3-5 years max. Even though it feels like it rides like the first day you picked it up, it probably doesn't. We slowly adjust as the suspension becomes less and less compliant. In any case, I've seen people that have not touched theirs for a decade or more but they don't expect much performance riding out of their bikes.
  3. md2420
    md2420 Well-Known Member
    May 10, 2016
    1,390
    564
    Chandler, AZ
    2014 Vision
    My shock started seeping oil recently. Still holds air and rides “fine”....but think I’m going to save up some coin and go with the Penske shock. Then I don’t have to worry about the air or the oil at that point.
  4. roadcouch
    roadcouch Well-Known Member
    Jan 1, 2013
    3,170
    5,389
    West of chicago
    2013 xc sunset red
    Mine had a loud squeak after a overnight rest daily. For about a week. No leak. Heald air. After a few miles each day it quieted down until a overnight rest. It does greased every tire change since birth. I took it in to Randy's cycle and they had told me it's a early sign of the end of life of the shock. Got 46,000 out of it with about 10,000 of that 2 up. Had it swapped out for OEM been fine since.
  5. Dan050
    Dan050 Well-Known Member
    Jun 8, 2012
    489
    263
    NE Indiana
    Cross Country Tour
    You say you lubed everything. But did you actually pull the rocker pivot pin and lube it?
  6. roadcouch
    Jan 1, 2013
    3,170
    5,389
    West of chicago
    2013 xc sunset red
    Not sure, the dealer does it. They have told me that they do inspect it at this at the time. Guess it's a wear item? I wish there was a video on this because I would do it myself. Just need a visual before I get into it
  7. Bam'sVision
    Mar 1, 2015
    24
    1
    Kansas City, MO.
    I didn't get that extensive but when I have a chance I'm going to try to get more in detail and see about the rocker pivot pin lube. Thanks
  8. Bam'sVision
    Mar 1, 2015
    24
    1
    Kansas City, MO.
    Mine is the opposite after it has sat it's barely noticeable but the more i ride it gets more significant. When it first started it would get better after more riding but now it seems worse the more I ride. This is probably the second season and it's just gotten worse. I just turned over 62,000 so it's probably just time to change it. Think that thing is about $600.
