Help with Ssripped Hhx head screw on LLoyds air filter | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by BobB, May 18, 2018.
  1. BobB
    BobB Active Member
    Aug 18, 2013
    394
    131
    central NJ
    Cross Country Tour
    Sorry for the typos on the thread heading.... Not sure how to fix that.
    Oh boy......I pulled my CCT gas tank last evening to clean my LLoyds Air Filter. There are 3 small hex head screw holding the retainer clip for the filter in place and I managed to strip the hex head screw. 4mm? I don't think I tightened it that hard when I installed it, but it seems frozen now. That and my novice skills got me into trouble. I haven't touched the other 2 as yet.
    I thought about clamping a vice grip onto the head and turning it, but I don't want to chance snapping the head off given it's on so tight or mangling it.
    I plan on spraying it with penetrating oil and letting it sit for a while before any action.
    Suggestions?
  2. Nuklhed
    Nuklhed Well-Known Member
    Jan 15, 2016
    1,166
    509
    Your Mom's House
    Your mom. I named her 'motorcycle.'
    Tap gently with a hammer.
    Use something like ajax cleaner. Spit on bit head, dip it in the ajax and use normally, but with a little more downward pressure.
    Trick I learned fixing UH-60s.
  3. BobB
    BobB Active Member
    Aug 18, 2013
    394
    131
    central NJ
    Cross Country Tour
    @Nuklhed - Good Idea. I'll try that. Thanks !! (Keeping my fingers crossed)
  4. BP6666VR
    BP6666VR Well-Known Member
    Dec 23, 2013
    4,388
    1,831
    World Citizen
    On YouTube there are some exulant videos on this subject ... Please take the time to watch some of them ...
  5. JamesBond
    JamesBond Well-Known Member
    Oct 29, 2015
    1,159
    404
    San Diego area
    2015 Magnum/ 2005 Big Dog Chopper
    Stick the wrench on it and tap it with a hammer at the same time that you turn it
  6. Ducatiden
    Ducatiden Member
    Mar 16, 2017
    91
    49
    MN
    14 Crossroads classic &1961 BMW R60 with sidecar
    I've removed rounded hex head by using Dremel or right angle grinder either tool with cutoff wheel. Make a slot across hex head and use flat blade screw driver, or use straight bit from driver set with 1/4" hex socket and rachet to remove. Good luck. Last resort if threads are fouled, then use an insert to repair, available at hardware or Auto parts store as complete kit- tap and insert.
  7. PDXLaserGazer
    Jun 3, 2013
    4,359
    1,551
    Molalla, OR
    rubber band across the tip of the Allen wrench may help as well (don't use the ball-end Allen wrench), works with Philips, but never tried with hex. Also, maybe a flat or Philips will fit in there. Chances are you won't snap the head off with vise-grips but if you do, you can slide the filter off over the exposed threads and grab the remaining screw with the vise-grips and replace the screw. Finally, a cheap Torx may work to bite into it. Whichever way, you'll want to replace the screw, maybe all of them. I hesitate to suggest the easy-out in this case but it's still an option if you are familiar with how they work.
  8. HenryT
    HenryT Active Member
    Feb 23, 2017
    441
    100
    Kane County, IL
    2015 Harley Davidson Breakout
    If you butchered it time to get Mid-evil and grab the vise grips. Just pull the damn thing out. replace with a self tapping bolt of similar size, that soft aluminum will accept new threads real nice.
  9. BobB
    BobB Active Member
    Aug 18, 2013
    394
    131
    central NJ
    Cross Country Tour
    Thanks for all the suggestions. Time to get to it.
  10. lou8700
    lou8700 Well-Known Member
    Dec 3, 2012
    5,772
    2,975
    St. Louis
    If you still have problems take a torx bit socket slightly larger than Allen head with a long extension and tap it down in there.
  11. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    11,960
    5,130
    South Florida
    2011 Cross Country
    Sears sells the easy out kit. Lowe’s and Home Depot should too. Good luck. The dremel slot idea is what I do.
  12. Gamewarden
    Gamewarden Active Member
    Jul 26, 2012
    597
    111
    Centreville
    How does the Ajax work, just curious.
