I'm stumped...hoping you all can help me out...maybe I can save a trip to the dealer.
Got a weird noise on coasting coming to a stop from the 20mph to 0mph range. (It seems worse if I have a passanger aboard). It sounds like rear brake rub but visually inspected brake and rotor (and all appears OK) and hit rear brake when it's making the noise (still makes the noise). Did the same with the front although it really sounds like its coming from the rear. I thought maybe clutch so when I heard it, pulled the clutch...still has the noise. Hard to explain but it's not a high squeal...more like a low frequency noise. I'm thinking it almost sounds like a bad rear axle. I've heard bearings go out in the past and there is no tell tale knock, knock, knock. Itdoesn't do it everytime which is stumping me as well. It really only happen on decelaration...steady low speed, I can't hear it.
Maybe the belt is too tight? Seems pretty taut to me but I'm a chain man and know little to nothing about a belt drive.
Anyone else have this problem in the past?
The 09 KP only has 2100 miles on it and yes I did the 500 miler at the dealer.
