Heated Grips | Victory Motorcycles: Motorcycle Forums
Heated Grips
Discussion in 'Victory Cross Country' started by Tailgunner, Aug 9, 2020.
  1. Tailgunner
    Tailgunner New Member
    Apr 6, 2018
    6
    2015 Cross Country
    What would be the best aftermarket heated grips for my 2015 Cross Country?
  2. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,534
    2,308
    Littlestown
  3. Chattanooga_Mark
    Dec 25, 2009
    5,390
    2,395
    Chattanooga
    2012 CCT, Wonderful in white
    Why aftermarket instead of oem, price? The oem heated grips are awesome.
  4. jmstang302
    Aug 18, 2013
    5,534
    2,308
    Littlestown
    When was the last time you saw a complete kit? I got the last new set I saw 2 years ago.
  5. Chattanooga_Mark
    Dec 25, 2009
    5,390
    2,395
    Chattanooga
    The individual parts are available new and likely used from the usual sources.
  6. IndyVictory
    IndyVictory Well-Known Member
    May 29, 2020
    1,380
    502
    Indianapolis
    Lot of money for that. My OEM are starting to deteriorate. I thought the threads I read on that were crazy but it is a thing. Rubber doesn't last forever and from my understanding Avon has same problem. I would probably go with Avon when my OEM does need replaced. They certainly look better. I know some do those sleeve things but I think that would increase diameter more than my short fingers would like.
  7. Pratt
    Pratt Member
    Jun 1, 2020
    33
    20
    Maine
    2013 Cross Country
    My bike still has to OEM as far as i can tell. I wonder if it's from the warn rubber. They burn my hands on low
  8. Sunbum
    Sunbum Member
    Aug 26, 2009
    66
    17
    Duvall
    2015 XCT
    I installed the Avon heated grips in May as my OEM rubbers were worn out. I have approx. 8k miles since.
    The Avons take a long time to heat up.
    The Avon’s do not get hot like OEM.
    The Avon switch is sometimes hard to discern between on/off.
    The Avon’s Grip material feels rough even wearing gloves on long rides (3500 mile ride in May and 3200 mile ride a week ago).
    The only thing I like better about the Avon’s is their look. Wish I could find some new OEM’s!
  9. BrotherWind
    BrotherWind Well-Known Member
    Sep 14, 2015
    2,048
    1,493
    I thought too that the sleeves, I use " grip puppies " , would be thicker than I could accept. On my GW they were thick but they ended up being very comfortable. I really like them. They're only some $15+ on Amazon so you might want to try. They feel great on my Vision. They're also not affected by the oem heaters and work perfectly. Just a thought. Good luck.
  10. mdhall41
    mdhall41 Well-Known Member
    Oct 8, 2015
    528
    365
    North Carolina
    2012 Victory Vision
    I'm considering grip puppies or leather wraps on my Vision as I have big paws and want something a little bigger in diameter without sacrificing the heated feature.
  11. BrotherWind
    Sep 14, 2015
    2,048
    1,493
    I had both. The puppies are much better, IMHO. If you go with puppies I found just the soapy water wasn't good enough. Really hard to get on until I added some compressed air. Than fairly easy and no ripping. So you know.
  12. mdhall41
    Oct 8, 2015
    528
    365
    North Carolina
    2012 Victory Vision
    Do you remember if you bought the oversized ones, they make a larger version designed for grips between 1.45-1.65 diameter. I need to measure my grips when I get home!
  13. BrotherWind
    Sep 14, 2015
    2,048
    1,493
    These are what I got. They increased to $19.99. Still very worth it.
  14. James2003x
    James2003x Active Member
    Jun 27, 2019
    228
    89
    Ooltewah, Tennessee
    2015 XCT
    I’ll have a complete set soon. one person has first dibs once they’re off but if he passes they will be available to anyone.
  15. jmstang302
    Aug 18, 2013
    5,534
    2,308
    Littlestown
    I'll be interested
heated hand grips 2015 victory cross country
