Heads up to 2010 CR Owners. | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by Richie271, Jun 27, 2020 at 9:52 AM.
  1. Richie271
    Richie271 Active Member
    Oct 18, 2014
    181
    76
    Long Island, NY
    2010 Victory Cross Roads
    I have been doing quit a bit of riding but for the last month or so I have had a loud clunking like rattle from the rear of the bike every time I hit a bump or rough road. As hard as I tried, I could not find the source of the noise.
    The other day I worked on the rear brake caliper, thinking it was the source because the day before, I found out if I did a quick, on off, touch of the rear brake, I heard a noise that was the same frequency of the clunking sound that I had been having. I also found if I dragged the rear brake while crossing a bump, no sound at all. While spinning the rear wheel by hand, I was hearing another sound coming from the wheel that made me think the one of the wheel bearings, that I just replaced last tire change, went bad.
    Well, yesterday, I backed the bike out of the bike garage, raised the rear wheel of the ground with a platform jack and started closely checking out the rear wheel.
    What I discovered was that the outer rim of the brake rotor was very loose, because all the buttons that hold the outer rim to the inner part of the rotor were so loose, that the outer part of the disk was just flopping around and causing all the noise that I have been hearing. So now I knew I must replace the rear rotor.
    While doing some research on the net, I discovered that this is a fairly common problem on the 2010 CR bikes that I had never heard about before.
    I have a used replacement rotor from a 2012, (the newer part number), arriving tomorrow to fix the problem. I will pull the rear wheel off tomorrow to do the job and at that time decide if I will install my new Avon Cobra Chrome tire to replace the Chrome that is on the bike now, or keep the old one on for a while longer. The old tire is worn square but seems to have plenty rubber left and is not down to the wear bars yet.
    Show Full Signature
    Richie271
    • Informative Informative x 4
  2. notaharley
    notaharley Well-Known Member
    Oct 1, 2012
    4,096
    1,713
    Effingham, NH
    VISION, BABY!
    Crazy!
    Had a 2012 that ran flawless for 50k miles.
    Miss that bike!
    Glad you got it sorted out!
  3. Richie271
    Oct 18, 2014
    181
    76
    Long Island, NY
    Thanks,
    I forgot to mention that I have over 71,0000 miles on my bike. Some others didn't get much over 20k before the rotor failed.
  4. PreachSF
    PreachSF Well-Known Member
    Dec 3, 2012
    1,352
    799
    Delray Beach, FL
  5. Richie271
    Oct 18, 2014
    181
    76
    Long Island, NY
    I finished the job yesterday. I installed the replacement used rotor and I decided to replaced the rear Avon Cobra Chrome tire with my new Avon Cobra Chrome . I still had plenty of rubber on the old tire at 13,154 miles but the tire was worn square from all the highway riding that I do. The tire was throwing the rear of the bike around when traveling over imperfections in the roadway and I was constantly having to correct the steering. I already felt the difference when putting the bike into it's garage. There are some elevation changes in the pavement leading to the garage that was throwing the bike from side to side with the old tire and I did not have that problem with the new tire. Riding the bike should be a lot less work now. Oh, I also washed the drive belt and the drive pulleys before putting the bike away.
    I am looking forward to trying the new rotor and hopefully not having all that noise from the rear of the bike when passing over bumps and rough pavement. I will report back as soon as I have a chance to try it out.
  6. grampahawg
    grampahawg New Member
    Sep 26, 2010
    13
    1
    east bend
    2010 crossroads
    same on my cr 2010 with about 8000mi, bought onr from ebc,seemed to be a little thinner than stock. but worked fine.
  7. Kurbs
    Kurbs theVOG.net Gold Supporter Gold Supporter
    Top Poster Of Month
    Dec 26, 2015
    5,583
    2,741
    2012 Victory Kingpin
    Very common issue with the BMW Brembo rotors. Never seen it on a VIC. But the fix was to use a non-Brembo rotor. I think you just got a bum rotor, as I never heard that on a Vic. Bet swapping it will be fine for a long time.
