I've noticed i have very little give on the throttle cable... i'm not sure you'd be able to go any taller without swapping the cables out. I've taken the handle bars on/off a couple times and adjusted/installed torque tubes etc. I'd think if you're going any taller you'll need to get another cable unless the routing changes for the cable. You def won't have enough to run the cable inside the bars if you go for a clean look.
