1 - 2 of 2 Posts
I know my bike has been lowered and I'm having rubbing issues, can someone measure the length of their shock set up for me. I'm not sure if my shock set up was changed or if it was the links that were changed out?
Top of the bolt housing is 15 3/4" to the bottom on mine?
Thanks for the help
I can't answer your question directly but this may help:
Ifyou have a copy of the manual for the bike or can find one online there is a step by step procedure in it for measuringand adjusting the suspensionwith you on it. I believe it says for a vegasthe bottom of the engine(Behind your pipesjust back of the front belt sprocket there should be a bolt head, this is the measure point)should be around 5 1/8" from the ground.
Even if the bike was lowered you may be able to tighten up the suspension a bit to keep you from rubbing.
I have been told you can never have the tire rub on the rear fender of these bikes, It could pull all of your tail light wiring out.
1 - 2 of 2 Posts
