Yeah no clutch slippage that I can tell where is the sensor at that reads thisMaybe the sensor is dirty. My understanding is that Victory uses a sensor to measure output sprocket speed, which sends that info to the ECU. The ECU uses the engine RPM info to determine what gear the bike is in. I can slighly slip the clutch and make the indicator change the gear readout. So maybe your sensor isn't reading the sprocket accurately.
Are you sure that your clutch is not slipping?
Serious ??? Never heard of this, GOOD POINT if true .....You may be lugging the motor. Keep it between 2.5-3.5K rpms for gentle cruising and see if it's more accurate.
I've seen many riders new to Victory say this and I think it's because they're babying the motor like it's a Harley. Vics like revs.
4.5-5K rpm shifts for having fun.
Rev it up!
*I can make mine tell me a wrong gear. It's not hard to do. Keep it revved and I bet it will be better.
Seems to be more of a specific thing to the Vision.I don't find low rpm to cause false readings on my bike.
The older Visions ('til '10) used the positive switching method, i.e. there's a sensor (switch) which senses where yer shifting linkage's positioned. The new models (+'10) use the RPM's vs speed through the ECU to determine which gear yer in. If, like VVB said...I sometimes see a 5-6 error but it is when I decided not to down shift to 4 yet when slowing to go through a town.
Ya lug or over-rev yer engine you'll get inaccurate gear positions displayed.You may be lugging the motor. Keep it between 2.5-3.5K rpms for gentle cruising and see if it's more accurate.
Rev it up!
What's weird is the older ones like my 08 show you the gear at all times.I get a kick out of how it doesn't indicate the gear (besides N) unless your clutch is engaged. Would think it could be done easier and more informational than that. I haven't done it, but I would bet that some have thought they were in 1st gear at a light, when they weren't.
The only way the computer knows your clutch is engage or not is that piece of spring metal that activates the switch on the handle bar.I get a kick out of how it doesn't indicate the gear (besides N) unless your clutch is engaged. Would think it could be done easier and more informational than that. I haven't done it, but I would bet that some have thought they were in 1st gear at a light, when they weren't.
Agreed, but it seems to be a cost saving matter. As DAVEofSAC noted, without a separate sensor, the gear indicator uses the fact rpm / speed is constant (and different) at each gear position inferred from crank and speed sensor readings. It's easy enough for an ECU to remember the last estimated gear position before a bike comes to a halt. But since a rider can switch gears during standstill that can't be tracked, outside of showing two dashes there's not much that can be done. Neutral seems to be a special case.I get a kick out of how it doesn't indicate the gear (besides N) unless your clutch is engaged. Would think it could be done easier and more informational than that. I haven't done it, but I would bet that some have thought they were in 1st gear at a light, when they weren't.
You're right, that does sound crazy. LOL. Specially since the shift star is on the complete opposite side as the sensor. So what you're saying is that the sensor isn't getting a ground?They changed to math form fixed switch because of the problems they had getting the switch to work right. Sounds crazy, but here is the solution. Replace the bolt that holds the shift star to the shift drum with a non coated bolt from a 2009. The problem is caused by improper grounding of sprung ball on the other end of the drum
That is what I am saying. Not sure on the email, but if I didn't reply I'm guessing notYou're right, that does sound crazy. LOL. Specially since the shift star is on the complete opposite side as the sensor. So what you're saying is that the sensor isn't getting a ground?
Hey @kevinx , did you get my last email??
