You can easily get 100,000 miles out of the belt.So who has used the gates belts on the cross country? I have 30000 miles on my stock belt, it still looks good but I thought about replacing it this spring.
Um ok, due to the good advice from these nice fellas I'm going to run it another 70000 miles.Mate, don't believe them, can't you hear it giggling at that decision? It's just waiting for the most inconvenient time to break, needs to be changed immediately!
I'll give you $50 for the old junk one.![]()
Belts are good for 100K plus miles, if you replace it please send me your old one, plenty life left in itSo who has used the gates belts on the cross country. I have 30000 miles on my stock belt, it still looks good but thought about replacing it this spring.
No need to touch belt adjustment on tyre changes if theyre done right.Have around 57K miles on mine and looks good. I inspect it from time to time, and so far, so good. Only adjust at tire changes, although once I readjusted it after had a tire installed by a shop I wasn't familiar with. Sure enough, they had it way too tight. If you want to break one that's the best way. Noe does my tires changes now. No worries. Like @Chattanooga_Mark , I have a new one in the wings. Guarantees I'll never have to change it.
Get in the queue mate, I've already offered him 50 bucks for it.Belts are good for 100K plus miles, if you replace it please send me your old one, plenty life left in it
And they are nice fellas too. Gotta watch that @Motorbikerx bloke though, he'll try and scab your belt for free AND want you to pay postage.Um ok, due to the good advice from these nice fellas I'm going to run it another 70000 miles.
How was the tension and tracking when you did that inspection?Okay, just want to share a little experience plus New Insights in regards to inspecting/replacing the Victory Drive Belt after mine suddenly just snapped and I got rear ended by another Biker (Yes $$) at just a little over 90k in 2017.
I had literally just carefully VISUALLY inspected my entire Original Drive Belt during another service and it showed no cracking, discoloration, chipped teeth or other unusual wear. So Yes, I was shocked and Pissed when it snapped far from home on a favorite Charity Poker run. Then I was even more pissed at myself later when I realized my ignorance in something I should have known being in the Automotive Parts field.
While belts are cleaner, lighter, cheaper, smoother, quieter and require less maintenance or adjustment than chains, they are made of Kevlar and carbon fiber and just like Automotive Timing Belts they suffer internal material fatigue over time and use. So while they look visually great, internally they become stiffer and more prone to sudden breakage. Not cracking in most cases as most mechanics that have repaired cars with snapped timing belts, they just suddenly snap clean.
I suddenly remembered this when I picked up the broken Victory Drive Belt and compared it to the much more flexible Replacement Victory Drive Belt. Night and Day in how flexible it was.
So Moral of the Story, besides visually inspecting your High Mileage Drive Belt, you need to remove it and check how flexible it still is compared to a New Drive Belt. Remember just because she’s pretty, doesn’t mean she’s safe. 😉 View attachment 639206
It was right on, I had just checked as part of my belt inspection. Early on years ago after having my rear tire replaced and getting belt squeal, I learned how to properly adjust and align my drive belt correctly myself. So the belt looked perfect and was set correctly.How was the tension and tracking when you did that inspection?
I’m out, but may be a fun game to play if you stay close to home, feel lucky, do ya?They will break. Just when?
I imagine that damage was done by the other bike, not the belt?Okay, just want to share a little experience plus New Insights in regards to inspecting/replacing the Victory Drive Belt after mine suddenly just snapped and I got rear ended by another Biker (Yes $$) at just a little over 90k in 2017.
