Got a Maverik(cheaper gas) and Chevron(up to 10 cents more per gal.)close to me. Is there really a diff in the quality?
+1 I won't fuel up at a real old station with old tanks full of crud. My riding buddies pulled into a station that looked like Orville and Wilbur Wright fueled up there, I said no way!kevinx01 said:My number one concern when I look at fuel is how old the tanks are. Pretty much every fuel you can get today is far supeior of the quality of stuff you gat as little as 5 years ago
Exactly what I found with my experiment. 93 is expensive and didnt offer any big advantages, 83 makes the bike ping and 87 works just fine.kevinx01 said:Since thes bikes do not use a knock sensor using 91 octane with ambiant temps below about 90 is a waste of money. If you want the best performance you use the LOWEST octane number you can; that does not ping
+1 on the toptiergasPutter said:I've tried different fuel in my cars and bikes and seem to get better mileage with Top Tier brands.
http://www.toptiergas.com/retailers.html
Always try to use the recommended octane. Figure the auto and bike fims wouldn't recommend it unless it was warranted. Also ge better mileage with it.
Octane recomendations are for a blanket coverage, and a machine operated at sea level in high ambiant temps ha vastly different needs then a machine at a couple thousand feet with lower, or higher temps. So what the manufacturer knows is that they can stay out of trouble if they list high recomendations on octanePutter said:I've tried different fuel in my cars and bikes and seem to get better mileage with Top Tier brands.
