Many Vics share the same harness, so likely a component that your bike doesn’t have.There is a capped yellow and black connector coming off of the fuse box What can this be used for. There is also one with a blue and purple wire View attachment 634756 leading to it???
Yup. Go read my edited post above. Was adding to it as you replied.I am just trying to find a spot to hook the blue wire from my amp to get keyed on power
Download your specific manual via the link I provided above and you’ll be able to see all of the wires and what is switched power or not.Thank you for the imput. Does anyone know off hand if one of these is switched and would work? I am not home to check things at this time.
