Fuel Pump | Victory Motorcycles: Motorcycle Forums
Fuel Pump
Discussion in 'Victory Octane' started by dclaeson, Aug 31, 2016.
  1. dclaeson
    dclaeson New Member
    Aug 31, 2016
    8
    2
    California
    Victory Octane
    I've had my Octane for a few weeks and around 650 miles. From day one when the engine is hot, there has been a loud noise that sounds like either the air filter or fuel pump. I didn't notice it when I test rode the bike, but five miles isn't really enough to get the engine really hot. I took it back to the dealer and the service manager said it was the fuel pump and it is normal for it to run continuously at that noise level.
    Is this really normal? Does anyone else's bike do the same thing?
    Thanks!
  2. VictoryOctane
    VictoryOctane Active Member
    Apr 8, 2016
    219
    57
    Minnesota
    Victory Octane
    Mine does this and a few others have noticed it. Especially when it is hot out and the engine is fully warmed up. No bad effects yet. I solved mine by putting on an exhaust and intake - now I can barely hear it. ;)
  3. bigsbigelow
    bigsbigelow Active Member
    Jun 1, 2016
    261
    93
    Metro Detroit
    Octane
    My fuel pump is audible but not loud. My input may not be the best because I have had my exhaust modded since like the second week I had the bike.
  4. Modus_Pwninz
    Modus_Pwninz Member
    Aug 16, 2016
    39
    6
    2017 Victory Octane
    My fuel pump is audible as well, but I wouldn't say 'loud'. Might need a video to hear it...
    I have had something happen twice now that has concerned me - just driving along and all of a sudden I hear a "THUNK!" from inside the gas tank and I feel it on my leg as if something inside moved and hit the tank. Freaks me the **** out...I dunno' if the fuel pump is moving or what, but it's so strange a sensation...
  5. Azvestor
    Azvestor Member
    Jul 7, 2016
    39
    22
    West side of Phoenix, AZ.
    2017 Victory Octane, 2012 Victory Vision
    I've heard the noise as well when the engine is hot, but I believe it is the radiator fan. If it was the fuel pump you would be hearing it when the bike is hot or cold.
  6. dclaeson
    dclaeson New Member
    Aug 31, 2016
    8
    2
    California
    Victory Octane
    Definitely NOT the fan. You can see that the fan isn't turning while the noise is present. The fan doesn't come on unless the bike is very hot and the weather is very hot. When I was asking the service manager about the fuel pump noise, I also told him I didn't think the fan ever came on. He proved me wrong by riding the bike around the block then letting it sit and idle for a while and the fan finally came on.
  7. dclaeson
    dclaeson New Member
    Aug 31, 2016
    8
    2
    California
    Victory Octane
    Yikes! I can see your concern.
    I love the bike, but I am working through the issues: Fuel pump noise, noisy/rattly brakes, squealing (final drive belt I think), inconsistent downshifting.
    My first bike was a CB1100F (before I got married), then a 25 year hiatus, then a VTX1300T. I'm a Southern California commuter and put on 11k miles a year. I like my VTX, but this bike is a BLAST!
  8. TexasTom
    TexasTom Member
    Jul 1, 2016
    89
    33
    Saginaw, Texas
    2017 Victory Octane
    No, it's not the fan. My dealer said it was the valve train, but I doubt that because they don't know anything about the Octane except for how to sell it, even though it sells itself LOL.
    It really was loud until I put the Biltwell Stingers on. Problem solved. I don't hear it now. I don't hear ANYTHING now LOL.
  9. VictoryOctane
    Apr 8, 2016
    219
    57
    Minnesota
    Victory Octane
    Does your bike have the "floating rotors" or the stock ones? I keep hearing about brake noises but I've never had an issue with mine and am just curious what the difference/issue is?
  10. dclaeson
    dclaeson New Member
    Aug 31, 2016
    8
    2
    California
    Victory Octane
    Stock - I'm not sure what the advantage of floating rotors is. A quick search says that floating rotors self-align to the the brake pads better (better stopping power) and run cooler, but when it comes time to replace the rotors I'll do more research.
  11. BBartlett
    BBartlett New Member
    Aug 7, 2016
    19
    5
    2017 Octane
    I got the same noise and I've also been very concerned about it definitely a high-toned clunk concerned sounded like it did come from the top end heard it at least three times distinctively anxious to hear what it is
  12. rodhotter
    rodhotter Well-Known Member
    Aug 5, 2013
    1,975
    256
    pennsylvania USA
    2013 victory hammer
    Vics have 2 piece rotors but not really "floating" unlike the EBC'S i replaced mine with, they buzzz on application + as noted floaters are said to help the pads set flat to the braking surface. it helps but bigger 4 or 6 piston units are needed on the Octane + Scout, a single uprated caliper is no xtra cost to mount + sometimes works with a stock master. my best braking bike i have now is a 2012 bonnie, about 500# wet, it has a direct mount pretech 6 piston caliper on it, stock master but the forks needed upgrading from the great braking causing excessive dive. a pair of drop in Bitubo cartridges cured that for about $500, self installed!!
2017 victory octane fuel pump
