1 - 8 of 8 Posts
Fuel pump won't Prime after a replacement which was the original problem. Now I'm thinking it was nothing wrong with the fuel pump at all. It did start first time but next ten times, no go, then started 5 times in a row. Next day won't start. Fuel pump won't Prime.
there are TWO parts to the fuel pump, did you replace BOTH? OR did you get a whole new pump? wait, model year makes a difference.
I bought the pump AND the pressure regulator. see post 15
good luck.
http://www.thevog.net/threads/new-owner-problems.120617/
Come to find out only by chance that as I moved the bike pulled in the clutch and try to start it at the same time I noticed that all of a sudden the end came on on the gear selector and it started right up. Later on it didn't show up and wouldn't start even though it was a neutral. Call the mechanic they didn't check that part and replace my fuel pump instead still didn't work of course. So they came to pick it up and hopefully will replace the neutral switch.
1 - 8 of 8 Posts
