1 - 3 of 3 Posts
Does the fuel controller play nice with the PCV? I have the PCV and am looking into the lloydz air valve for the 09+ bikes to get rid of the backfiring. Any help is appreciated. I also have the SS intake.
Are you asking ifLloyd's IACworks with the PCV?
It looks like you are asking if a fuel controller works with a PCV. That answer would be "why would you need two things managing fuel and air"
I believe the IAC does work with the PCV, although I would ask Loyd.
I put the IAV on before adding the PCV. I'd say the IAV isof marginal help but probably worth the price. If I changed maps on the PCV I usually had to readjust the IAV as more popping would start to occur. The IAV and the autotune DO NOT work well together as the autotune is constantly changing the a/f ratio and thereforethrowing the IAV outta sync.
RR
1 - 3 of 3 Posts
