So is it as Simple as removing the black wire from the front and rear 02 sensor to accomplish the same effect as buying connectors with resistors?
Removing the black wire and leaving the connectors connected will this prevent the check engine light from coming on? I have a 2017 vision so I don't think I can Leave them unplugEd.
I have had mine disconnected for about 900 mi now and no dash lights.
I don't recall anyone on here posting about check engine lights coming on when they disconnected the O2 sensors.
The resistors would just fool the ECU into enriching the mixture. But from what I determined these are narrow band O2 sensors so the ECU can lean the mixture to meet Emissions standards the biggest effect is after a cold start. I have not noticed any change in performance or driveability when cold and since I disconnected them after I installed my Stage 1 mufflers fuel controller and secondary filter, I can't comment on any change in performance attributed to just disconnecting them.
Just do it. I had a local shop owner tell me not to disconnect them as it could cause more harm than good but, later he admitted he was not familiar with the Vic 106 and after some research he recommended I disconnect them.
With the mods and Fuel controller the bike has better torque, better throttle response, runs noticeably cooler and just runs stronger all around.
