Very carefully, apply some high temp bearing grease (molybdenum) to the back of the brake pads. Put it on the perforated backing piece on the pad. This will dampen the vibration from the pad causing an audible frequency (noise).
BE SURE TO NOT GET ANY OF THE GREASE ON THE PAD ITSELF!
Also, when installing the pads be sure all the spring fittings are in-place, the pads are seated all the way up (I know sounds remedial but I rode 'round for months before I found the both front pads, on the inner pads, were out of the upper slot), and lastly be sure yer bearings are GOOD. I had a problem with a rear brake once... whenever I did ANY work on the rear (tire change, brake pad change,...) the rear would squeal (more like groan) after reassembly. I used the grease trick most times to eliminate the noise. Eventually, like after 30kM, I found the rear bearings were BAD! Now mind ya, I'd had the bike into a shop to fix the squeal a coupla times. Also, I was goin' through rotors and pads like crazy before I found the problem.
Audible frequencies are indications of mechanical play (somethin's loose).
