fork oil | Victory Motorcycles: Motorcycle Forums
fork oil
Discussion in 'Tech Q&A' started by grampahawg, Jun 29, 2020 at 4:27 PM.
  1. grampahawg
    grampahawg New Member
    Sep 26, 2010
    15
    1
    east bend
    2010 crossroads
    i over filled my forks,very harsh ride,need to know if there is away to suck out a few cc's without taking tubes out of triple clamp?? 2010 crossroads
  2. mrmegadeth
    mrmegadeth Active Member
    Mar 11, 2012
    645
    87
    Houston, TX
    2009 Kingpin
    big syringe?
  3. walks35
    walks35 Well-Known Member
    Sep 18, 2009
    614
    291
    NW Burbs of Chicago
    2004 Victory Kingpin
    Welp, I've replaced my oil and seals several times on my Kingpin but I'm not sure if you can siphon out of the top. If you know you can then cool and stop reading here. Adding through the top, yes I have heard of riders doing that.
    So, I guess if I were going to give it a go I'd jack the bike up and remove the front wheel so I can get at the the plugs inside the bottom of each tube. Keep a measuring cup under each fork, loosen the bolt (8mm I think) and slooooowwwwly let some oil drip out. Keep the amount removed on each side even.
    Once you're done and everything is put back together if they're too spongy I do believe you can open the caps and pour some fresh oil back in.
    Let us know how it goes.
  4. grampahawg
    Sep 26, 2010
    15
    1
    east bend
    2010 crossroads
    siphon i knew, was wondering about spring pressure when removing top caps.
  5. walks35
    Sep 18, 2009
    614
    291
    NW Burbs of Chicago
    Can't speak for XR but you can pop the caps off Kingpin forks and springs stay put. I thought that was common for all Vic forks but Guessright-o-meter has been off lately. There must be a YouTube out there about it. I'd call an old Vic shop or the VicShop itself to confirm if no one else replies.
    Good luck!
  6. grampahawg
    Sep 26, 2010
    15
    1
    east bend
    2010 crossroads
    should work,same style forks. thanx.
