Fairing 12v outlet | Victory Motorcycles: Motorcycle Forums
Fairing 12v outlet
Discussion in 'Victory Cross Country' started by slej, Dec 30, 2015.
  1. slej
    slej Well-Known Member
    Sep 6, 2013
    731
    454
    Chesapeake
    '17 Magnum, 03 Vegas, 09 Jackpot, 2016 Slingshot
    Hey gang, hoping someone can help. I noticed awhile back that there was no power to the 12v outlet in my fairing. I took off the right side cover to check the fuse and it was good. I then can to the forums and found a thread (can't seem to locate it today) where a couple guys were saying that this can come unplugged inside the fairing. I decided it wasn't important enough to worry about at that time...fast forward and I have got a few days of cold weather and rain in the forecast so I thought I would dive into the investigation. Well I got the outer fairing off, and then had to remove the left hand "speaker enclosure?" Sure enough the 12v outlet has two bare leads on the backside. Only problem is that I don't see a plug anywhere...Could it be that when the P O had the "Extreme Audio 6 speaker set up" added they cut the plug for the 12v off and used it to power the amp? Anyone have a picture of what the plug is supposed to look like?
    [​IMG]
    [​IMG]
  2. SubDude
    SubDude Well-Known Member
    Sep 12, 2014
    2,090
    834
    South East Michigan
    16 Chieftain Silver Smoke
    I'll bet that's exactly what the PO did. Mine are cheesy, cheap white connectors with single wires for each. Don't have my fairing off right now so I can't take a picture for you.
  3. slej
    Sep 6, 2013
    731
    454
    Chesapeake
    Thanks sub dude, I have looked at it gone over with a fine tooth comb and come to the conclusion of the connectors just aren't there. Now my dilemma is where do I find a 12 volt power supply to power of that outlet or preferably a USB outlet
  4. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    20150327_165022 (Medium).jpg if that is the right side of fairing that's the ambient temp sensor. like this one
  5. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    temp.jpg here is another shot
  6. SubDude
    Sep 12, 2014
    2,090
    834
    South East Michigan
    You all see that white connector with white wire under the circle vision nut posted? That's what my 12V cig lighter/ power is on my XC
  7. SubDude
    Sep 12, 2014
    2,090
    834
    South East Michigan
    There is another connector on the left side, inside the fairing ( right side of the bike) inside the fairing on XC. It was unused on my XC and I wired my Cirrious lights to it.
  8. SubDude
    Sep 12, 2014
    2,090
    834
    South East Michigan
    Duh! I quoted my own post to edit it. Sorry! Bigfoot will probably chastise me for etiquette.
  9. slej
    Sep 6, 2013
    731
    454
    Chesapeake
    Thanks guys. Getting back at it today and hoping to have her buttoned up in time for the polar bear ride tomorrow. I suppose I can ride the Vegas if needs be, but that XC sure is a warmer ride lol. Hooking up the DGD keyless while I am at it.
  10. slej
    Sep 6, 2013
    731
    454
    Chesapeake
    Well got her buttoned back up, still no 12v, but on the bright side, the Digital Guard Dawg is working great!
  11. SubDude
    Sep 12, 2014
    2,090
    834
    South East Michigan
    Did you see an unused connector right next to the harness where you plugged in the DGD? That's where mine is.
  12. slej
    Sep 6, 2013
    731
    454
    Chesapeake
    Saw one connector (well pair of plugs) one I assume was a ground/return and the other was constant hot. Just a little hesitant to use the wires without knowing where they come from of what fuse they go through. I will try and find the wiring diagrams and tackle it when I do the HMD bars that are sitting on the shelf calling to me ;)
  13. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    11,838
    5,082
    South Florida
    2011 Cross Country
    I thought the 12v connector was powered up all the time. If someone disconnected it to power an amp how is the amp shutting down? Speaker signal? Only other thing to do is run a set of fused wires to the battery. That will give you a direct connection to plug a Battery Tender cig lighter gizmo in and keep your battery up.
    Just a thought.
12 volt outlet for harley fairing
2014 victory cross country using 12 volt plugin
fairing 12v plug
victory cross country 12 volt plug fuse
victory cross country 12v constant power
victory cross country outlet
where to get 12v constant on victory cross country
