1 - 3 of 3 Posts
Hi folks, have a 2010 CR with factory driving/Fog lights. I use mine for ditch lights as I am in the country most of the time. Factory wiring is low-on, and I want high-on. Anyone done it?
I traced the 2 plug harness back to the main harness under the tank, but cannot find where the source or switch source is..
Thanks guys..
2000 miles so far this year in N.D.
Wade
what I would do is wire direct to the battery, come off the battery to a relay and wire in a toggle switch for an off/on switch then you can run the lights anytime you want.
1 - 3 of 3 Posts
