Engine Rebuild Kit | Victory Motorcycles: Motorcycle Forums
Engine Rebuild Kit
Discussion in 'Victory General Discussion' started by Goodguy28, Dec 26, 2017.
  1. Goodguy28
    Goodguy28 New Member
    Oct 17, 2016
    9
    2
    North Iowa
    2007 Kingpin
    I'm not finding anywhere to get a rebuild kit. I'd like all the gaskets, bearings, and bushings to rebuild the engine and transmission of my 07 Kingpin. Nothing is broken, but I'm thinking of some internal upgrades. She has 60k on her, and was doing some weird things with shifting, so I'd like to just tear down, and inspect everything over the winter, so I don't have problems in season. Who do y'all get that from? Do you have to just buy it all by the piece?
  2. Half_Crazy
    Half_Crazy Well-Known Member
    Aug 23, 2008
    23,393
    9,533
    Great Mills, MD
    Bikeless
    No "kit" that I am aware of...
    If you're going to rebuild it, will you go back all stock? The 2007 is a great platform for upgrading...
    How far are you from De Soto?
    Victory Motorcycle Performance & Service - The Vic Shop
    I just did what you're doing last spring. All new trans, freshen up the heads, new top end, all new gaskets, seals, o-rings...
  3. Goodguy28
    Oct 17, 2016
    9
    2
    North Iowa
    2007 Kingpin
    Yeah, I had her down to Rylan for the dyno last spring, and plan to again this time. But, I'm just the type of gearhead that does my own work, other than tuning on the dyno.
  4. Goodguy28
    Oct 17, 2016
    9
    2
    North Iowa
    2007 Kingpin
    As far as internal upgrades, I'm just thinking of higher compression and some flow work on the heads, mainly. I think, as far as gaskets, bearings, and bushings, stock should suffice. I also think I'll do the underdrive pulley. Hey, Half_crazy, what is the part number for the belt you're running? I don't want to invest in a new stock belt, and then have it be too long.
  5. Half_Crazy
    Aug 23, 2008
    23,393
    9,533
    Great Mills, MD
    Bikeless
    Belt for Buell 1125R
    Part #: G0500.1AMG
  6. Half_Crazy
    Aug 23, 2008
    23,393
    9,533
    Great Mills, MD
    Bikeless
    The Victory engine is sh!t simple to work on.
    Replace all the bearings in the transmission. Look close at the gears and shift forks. I just bought the whole main-shaft assembly and rebuilt the others. That was about $1200.
    The difference between just doing high compression and doing a big bore (109") is only a like $350-$400. The 109 is a solid 125 HP torque monster. The thing that will improve torque the most in these engines is a bore increase.
    As far as the heads, a freshening up and a multi-angle valve job is really all that's required for under 130+ HP. It's really easy to mess up these heads by cutting on the ports if ya don't know what you're doing.
  7. iabob
    iabob Well-Known Member
    Dec 20, 2010
    17,028
    5,422
    Des Moines
    Victory Kingpin
    If you're thinking of something like Lloyd's 11-1 pistons I agree with HC, just get them as part of a big bore kit. OR...I had Rylan do some upgrading a couple years ago. 08-newer Vic Pistons in an 07 or older 100" bumps the compression to about 10.2-1. Combined with Torque Tubes, RPW Thor, rev extended ecu...I'm VERY happy with this set up.
    • Informative Informative x 2
  8. Goodguy28
    Oct 17, 2016
    9
    2
    North Iowa
    2007 Kingpin
    Thanks for the info guys. Back to the original question. Where do you source your gaskets, bearings, bushings, and o-rings? Is there an easy way?
  9. Goodguy28
    Oct 17, 2016
    9
    2
    North Iowa
    2007 Kingpin
  10. Half_Crazy
    Aug 23, 2008
    23,393
    9,533
    Great Mills, MD
    Bikeless
  11. poptop
    poptop Well-Known Member
    Apr 25, 2010
    2,643
    633
    Vermilion
    09 Black Kingpin Prem rpw Thor 2 into 1. cams and ajustable timing wheel S+S intake and flash
    Just out of curiosity I to will be in that 120 to 125 tourqe range ,what is the sugested clutch upgrade or recomendation?
  12. Half_Crazy
    Aug 23, 2008
    23,393
    9,533
    Great Mills, MD
    Bikeless
    I'm not a fan of aftermarket clutches. Mine is original OEM with a stiffer spring in it. Cheap and holds fine.
    Barnett Billet Clutch Plate - LLOYD'Z Motorworkz
04 victory vegas top end rebuild kit
2005 victory kingpin engine rebuild kit
cost to overhaul victory vegas 8-ball
cost to rebuild victory engine
how to repair a victory freedom transmission
rebuilding victory 106
top end rebuild kit for victory 1500
victory 106 engine
victory 106 rebuild kit
victory 1500 engine rebuild kit
victory motorcycle rebuild kit
victory motorcycles v92 engine rebuild kit
