Engine Light along with Headlight Troubles | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Hammer' started by Lunchbox_USMC, Oct 22, 2015.
  1. Lunchbox_USMC
    Lunchbox_USMC New Member
    Oct 22, 2015
    23
    5
    Champaign, IL
    2017 Cross Country
    Got a Hammer I picked up a couple months ago and just started having a problem. As I'm riding along, my brights will suddenly come on and the engine light comes on. If I kill the engine and restart it goes away for a couple minutes but then happens again.
    I plan on cleaning battery terminals, and checking wiring, but wondering if anyone else has had this happen.
    Thanks!
  2. tree1979
    tree1979 Well-Known Member
    Jan 10, 2014
    4,220
    1,389
    Birmingham, AL
    2007 Victory Kingpin
    Sounds like frayed or rubbed wires. Check the wires coming out of the headlight bucket. Have heard of some wires getting pinched or having the outer wire jacket rubbed through at the housing. You might be getting a short.
  3. Lunchbox_USMC
    Oct 22, 2015
    23
    5
    Champaign, IL
    2017 Cross Country
    I figured something like that. I'm going to pull the tank over the winter and double check the wiring. The bike is a rebuild, and based on the short time I've had it, the wiring on this bike is not the best. I had to have the entire back end re-wired about a week after I bought it.
  4. tree1979
    Jan 10, 2014
    4,220
    1,389
    Birmingham, AL
    You should be able to check this by taking the top of the headlight bucket and not removing the tank. Good luck and report back if you get if sorted out
  5. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    Hey if its a pinched wire it could start a fire and burn up your bike.
    Take a day and look now
  6. tree1979
    Jan 10, 2014
    4,220
    1,389
    Birmingham, AL
    Apparently the OP didn't find the issue, bike caught fire and exploded wth him on it.
