I picked up an '08 Kingpin 8ball, and it absolutely is missing a ton of the snarl my '06 Vegas 8ball has.
I know they changed the injection also, but the strong compression exhaust pulse on the 06 is definitely not there in the 08.
Researching, it's pretty clear that the difference is that full point of compression.
I figured I'd replace the '08 pistons with the 06/07 pistons, but the part numbers are listed as THE SAME in the part finder. Did they get smart & drop the 8.7 piston? or lazy & drop the 9.8 piston?
Did they change the head combustion chamber to drop it down? I heard that the '08 heads were "opened up for better power, but were crack-prone" better power sounds like larger ports, but that doesn't drop compression. just got me thinking about the heads when I heard that. I had made the assumption the heads were all the same, since I don't see much discussion on them (compared to car head discussions).
Or change the base gasket/cylinder height so the pistons are further down in the jug?
I can shave the heads for a smaller chamber or top of jugs to get pistons to zero deck like I would with a car, but would rather KNOW the change & do it the same as factory instead of experimenting.
The KP will just be a fun cruiser.
Hoping I can just fix the compression & add tube intake for a strong street engine.
I really don't want to have to rip open the '06 to measure & compare components, as it runs like a champ as-is.
If any of you guys who do this for a living can clarify?
KevinX ?
I'll share anything I can find out as well.
Thanks in advance!
KevinX ?
Thanks in advance!
