engine dies after starting | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Vision' started by just wanna ride, Oct 4, 2020.
  1. just wanna ride
    just wanna ride New Member
    Jun 9, 2018
    13
    7
    2013 vision
    hello guys looking for a little help. i have a 2013 vision.the bike starts and runs for about a minuite thens dies.the voltage guage reads low at first then goes above 14 volts.then the thing quits running.i have made sure battery connections are tight.i jumped across the circuit breaker to make sure i had voltage on both ends.when it dies it will not restart unless you cycle the kill switch.it will start back up but still quits .any help would be great thanks
  2. lou8700
    lou8700 Well-Known Member
    Dec 3, 2012
    5,166
    2,484
    St. Louis
    Does it crank but not start or won't crank until you cycle the kill switch?
    Cycling the kill switch primes the fuel pump. Wonder if the pump is getting weak.
  3. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,365
    1,011
    WV Appalachia
    Goldmist/Black 14 XCT
    I would get that battery load checked, amps, you already covered most of it. Battery is 7 yo now. Then like Lou mentioned fuel. I would check fuel pressure.
  4. just wanna ride
    Jun 9, 2018
    13
    7
    2013 vision
    engine cranks fine.i will remove the battery and test it monday.looks to be a replacement battery.
  5. IndyVictory
    IndyVictory Active Member
    May 29, 2020
    538
    157
    Indianapolis
    My bike would die trying to idle. It was just the battery. Much like you describe the voltage would read low because it was taking all the battery had to crank over engine. It didn't have enough power in it to keep it running. The bike charging system can only handle so much. If it's all going to dead battery then the rest isn't getting sufficient power.
    • Informative Informative x 2
    • Funny Funny x 1
  6. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    3,965
    1,480
    Littlestown
    Howmuch fuel is onboard?
    If 1/4 tank or less, stand the bike up straight. There's only 1 pickup and it's in the right tank...
  7. Pauljp
    Pauljp Well-Known Member
    Nov 28, 2013
    1,098
    636
    Quebec Canada
    2014 Cross County Tour
    Sounds like fuel to me.
    With what you said it sounds like fuel starvation. When you cycle the kill switch it primes the fuel and then starves again.
    Make sure there is enough fuel in the tank, and then check your fuel system.
  8. 53canuck
    53canuck Well-Known Member
    May 25, 2013
    1,690
    641
    Left Coast, Canada
    2011 KP
    Running out of fuel would be my first guess too. With the voltage gauge reading low to begin with are you idling too slow? When you start the bike push the revs up to 2000. What does that do to the voltage gauge and also to the time it takes to stall?
  9. Flyboy
    Flyboy Well-Known Member
    Aug 29, 2014
    14,565
    5,439
    Victory Boardwalk
    I would say Battery, but the last guy had no fuel onboard, so put gas in it first and then battery and how old is it and did you ever kill it?
  10. PreachSF
    PreachSF Well-Known Member
    Dec 3, 2012
    1,467
    900
    Delray Beach, FL
    check your fuel pressure ... should be 51 psi at prime and hold, and stay at 51 while running. could be the pump or just needs a new filter
  11. just wanna ride
    Jun 9, 2018
    13
    7
    2013 vision
    I removed the battery.test battery 450 cold cranking amps 12.8 volts.battery good.bike has 3/4 fuel in tank.i am leaning towards kill switch since i gave to cycle it after it quits to get it to start.it acts like electrical the way it quits.
  12. PreachSF
    Dec 3, 2012
    1,467
    900
    Delray Beach, FL
    ... could spray some non-chlorinaed brake clean into the switch and see if that helps clean up the contacts ... before replacing the switch
  13. Deltaflash
    Deltaflash Well-Known Member
    Apr 20, 2018
    497
    311
    California
    Vision, Vrod, Vstrom
    JWR,, Sounds like the kill switch is working properly if you are toggling it and the bike starts back up.
  14. Deltaflash
    Apr 20, 2018
    497
    311
    California
    In the service manual on page 19.34 it shows a 40 Amp breaker (you have jumped) another 10 Amp breaker to the ignition and a 301 chassis relay. The 10 Amp breaker or the chassis relay might be worth checking out if is not the fuel pump.
    Good luck
  15. just wanna ride
    Jun 9, 2018
    13
    7
    2013 vision
    Kill switch checked ok.good voltage on both sides of circuit breaker.i am going to check fuel pressure tomorrow since u jyst read another thread with same concern his was a bad fuel pump
