1 - 2 of 2 Posts
I installed the Zumo 660 on my 09 Vision. I wired it in by soldering in new connectors to the Zumo mount and Victory wiring connection. The Zumo works like a charm. The problem is now my high/low beam, heated grips and cruise control don't work. I'm fairly sure I put all connections back in original locations. The 20A headlight fuse checks out as being good. I'm in over my head here. Any suggestions?
Discussion Starter · #2 ·
Update: All is working except the cruise control. The light at the on/off switch comes on but nothing at the dash display and the unit does not engage. The brake light appears to be functioning fine so I don't think it is that. Any suggestions?
1 - 2 of 2 Posts
