It is Demo days in my home town and we will be doing some dyno runs, comparing a stock cross country,t stage 1, to stage 1 with custom pipes. I will try to post the results later.wkohn said:Does anybody know where I can find Chassis dyno results for any of the stock touring Victorys?
Thanks,
Bill
You are making the mistake of being stuck on peak numbers. The torque curve with the S1 pipes looks to show a 7% increase overalljophez said:I agree that the stage 1 is stronger, but I guess I expected it to even stronger yet. Maybe my expectations were too high.
You're right, I am looking closer at the torque curve and it does stand out above the rest.kevinx01 said:You are making the mistake of being stuck on peak numbers. The torque curve with the S1 pipes looks to show a 7% increase overalljophez said:I agree that the stage 1 is stronger, but I guess I expected it to even stronger yet. Maybe my expectations were too high.
The RPW's don't fair to great, but I have a couple things to try on a friends bike to see if we can fix that. To date the best I have seen wer a set of straight pipes welded into the stock mufflers along with a VFC, and filter, and removed weather strip 89/106robbybintz said:has anyone tried the rpw or stright pipes
You can reduce the restriction after the cats. They do it on Camaros and Mustangs all the time and get improved performance.rossco said:the cats are in the header so you have to get to 80db so you can lable the test is in the fed regs so why change pipes?
