DYNA BEADS | Page 2 | Victory Motorcycles: Motorcycle Forums
DYNA BEADS
Discussion in 'Victory Cross Country' started by island hunter, Sep 27, 2015.
  1. primethious
    primethious Well-Known Member
    Aug 14, 2013
    8,027
    2,457
    2012 Victory Cross Roads
    When you pour the beads through the tube and into the valve stem just do a few at a time and it's all good. Get in a hurry and try to force too many at once and they clog things up. Just take your time.
  2. mister-g
    mister-g Well-Known Member
    Dec 19, 2012
    2,959
    1,751
    massachusetts - 2014 vision tour
    2014 vision tour
    :campfire1: I'm a believer in the dyna beads. I used them in the last two sets of tires and have seen MY best even wear to date , good longevity and so smooth you forget it can even be an issue. I did get a thou or two more out of the E'3s but the bridgestone exedras held up well and were a lot quieter and cheaper. the stone rear got 12 thou and the front went 14 thou to the wear bar so with results like that i'll be running with the exedras till further notice :) ,,, your results may vary. :smile_popcorn:
  3. caw391
    caw391 Member
    Oct 21, 2013
    153
    10
    North Las Vegas, NV.
    2013 Cross Roads Classic
    balancing beads are ok inside of an inner tube? So far, all I've seen was tubeless tires... thanks.
  4. lou8700
    lou8700 Well-Known Member
    Dec 3, 2012
    5,710
    2,928
    St. Louis
    This is what they have on their website: DynaBeads Tire Balancing Beads
    A: Absolutely! As a precaution, we strongly suggest a new tube with a new Dyna Beads application to avoid the problems of compressor oil accumulating on the inside over time. It turns gummy and the beads will stick to it.
  5. mastrblastr
    mastrblastr Active Member
    Sep 15, 2015
    214
    163
    BC Canada
    2011 Victory Cross Country Tour
    Had Dynabeads in my old TC Deluxe and run them in my XC. Never using weights again. Dynabeads keep the tire balanced no matter what. They have a video on YouTube of a water bottle on a cordless drill with a weight taped to the side, and then showing the difference running the drill with and without the Dynabeads. Pretty compelling video.
  6. Richie271
    Richie271 Active Member
    Oct 18, 2014
    222
    108
    Long Island, NY
    2010 Victory Cross Roads
    I used Dyna-Beads in two Suzuki Boulevards for 84,000 miles, with tubes, before I got my CR and they were excellent. Great mileage and ran smooth.
    I am now using them in the tires of my CR. Second set and very happy.
  7. Dagw00d
    Dagw00d Active Member
    Jul 17, 2014
    210
    64
    Waverley, Nova Scotia
    2017 Indian Chieftain
    Work great on my tubed XRClassic.
  8. rman
    rman Active Member
    Mar 19, 2011
    120
    31
    meriden
    04 victory kingpin
    I know this is an old post, but just learned of ride-on after having a nail puncture my rear tire. I was hoping to get the tire patched as it still had 4 to 5k left on it. Ended up replacing the tire. I was wondering if ride-on is meant to be a permanent fix. If not, how would one know he had a puncture if this stuff seals it?
  9. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    11,848
    5,083
    South Florida
    2011 Cross Country
    Yes old thread and old enough to say I have changed tires and didn't use ride-on this time.
    Couldnt get my tires to balance out with the product.
    The sealing nature of the product is not designed as a permanent seal but to get you off the road safely.
  10. Darth_v8r
    Darth_v8r Well-Known Member
    Apr 17, 2015
    1,735
    923
    Mesa, AZ.
    2016 CC8BALL, 2017 Kawasaki Versys 650
    Carry a plug kit. It doesn't take up much space and you will need it eventually.
  11. 1stVictory
    1stVictory Well-Known Member
    Feb 14, 2012
    6,447
    1,654
    Edmonton, AB
    2012 Pearl White CC Tour
    That's the whole point. The tire would be compromised and you'd have no idea. Better to use a TPMS of some sort and know your tire pressures than not at all. Each to their own.
  12. slickvic
    Dec 22, 2011
    11,848
    5,083
    South Florida
    2011 Cross Country
    Once the puncture occurs the tire will loose some pressure before the sealant finds its way to the hole. You may feel it and you may not. Check tire pressures often and inspect your tires.
  13. Scuba77
    Scuba77 Active Member
    Jun 16, 2015
    343
    120
    St Augustine, Florida
    2007 VT-1100C2
    Make sure the inside of your tire has no gunk in it before installing the beads. The dealer installed some during my Vision tire install and the bozo got goop in my tire, the beads stuck to one another and made the bike shake really bad. They ended up cleaning the tire and just put a regular weight on it.
  14. primethious
    Aug 14, 2013
    8,027
    2,457
    I wash my new tires in the bathtub with warm soap and water inside and out then dry them before installing them.
    Any oils from manufacturing are washed away.
    • Useful Useful x 2
  15. tree1979
    tree1979 Well-Known Member
    Jan 10, 2014
    4,220
    1,389
    Birmingham, AL
    2007 Victory Kingpin
    Do you put on some soft jazz and light some candles for them too? :huepfenicon111:
    • Funny Funny x 3
