Drive Belts after 31 tooth pulley install | Victory Motorcycles: Motorcycle Forums
Discussion in 'Poll Threads' started by LEVON106, Apr 30, 2021.
  1. LEVON106
    LEVON106 Well-Known Member
    Mar 24, 2017
    571
    274
    London Ontario
    2006 Hammer and 2016 Magnum 74 Norton Commando
    Made the swap today on My 06 Hammer to the 31 tooth pulley and will need a shorter drive belt. Am told the Buell 1125R belt is the way to go. Is there a preferred source to order this item from? Any suggestions would be greatly appreciated. Thanks
  2. Half_Crazy
    Half_Crazy Well-Known Member
    Aug 23, 2008
    23,387
    9,508
    Great Mills, MD
    Bikeless
  3. Half_Crazy
    Aug 23, 2008
    23,387
    9,508
    Great Mills, MD
    Bikeless
    I was just thinking... I was told the belt doesn't work on wide-tire bikes. The tire will rub the swingarm.
  4. BP6666VR
    BP6666VR Well-Known Member
    Dec 23, 2013
    3,996
    1,643
    World Citizen
    Correct, the shorter belt will make the tire rub the swingarm, ONLY ON wide tire vic's
    I slotted the swingarm holes, easy job
  5. TommyGunn
    TommyGunn Active Member
    Feb 28, 2018
    141
    69
    Lewis County, Washington
    Vision
    As a past Buell owner New Castle HD is great to deal with. And aftermarket Buell belts are junk, only buy oem.
    • Useful Useful x 2
  6. skipbarberman
    skipbarberman Active Member
    Jan 7, 2021
    158
    166
    Hammer
    As a current Buell owner, +1 on New Castle and OEM belts
  7. BP6666VR
    Dec 23, 2013
    3,996
    1,643
    World Citizen
    But it does not fit on his bike, tire will rub, he has a wide tire ...
  8. LEVON106
    Mar 24, 2017
    571
    274
    London Ontario
    Thanks so much for the info. I'm taking that you had to grind out some material in the adjustment slot. About how much?
  9. BP6666VR
    Dec 23, 2013
    3,996
    1,643
    World Citizen
    Yes i needed 3 mm if i remember correctly, i drawn the slot real nice and did a pencil grinder first within the lines then got a long round file, that filed trough both slotholes, so everything stayed straight
    It was easy enough job, and you have the axel to check all the time while you file the last material away ...
  10. Half_Crazy
    Aug 23, 2008
    23,387
    9,508
    Great Mills, MD
    Bikeless
    The Buell belts are Goodyear...
    [​IMG]
  11. PreachSF
    PreachSF Well-Known Member
    Dec 3, 2012
    1,675
    1,086
    Delray Beach, FL
    YOU DO NOT NEED A NEW BELT WITH OUR UDP
    if you dont have enough tension after install .. just take a regular sharpie, follow the curve on the REAR axle slot (both sides) and take a round file or dremel and file/grind away the thickness of that sharpie line. (about 3-4 mm im guessing) ... at that point you should have enough room to correctly tension / align the STOCK belt. ive been at conquest customs for a decade and have done this install with ZERO problems. save yourself some money, no new belt needed. period.
